as of late I have been eating anything and everything as well as really pushing myself at the gym. If I dont hit the same weight and reps from the week before or even improve on the last log, i do another set or two until i feel that I make up on it. That has been for all exercises in my routine.
Also for the big lifts in my routine squats, deads, bench and overhead press, i mix up the rep range for my sets, generally 10-15, 10, and finish with 5.
Sounds good mate, when I started gyming I weighed 65kg so I know what it's like :)
For reference I was mid 90s at my heaviest and am now around 87-88 and I'm only really in it for general strength, fitness, and looks.
You will get there, but eating should take up as much of your mental dedication as the weights, it did for me as a hard gainer.
yeah eating is hard. work has been in my ear about stopping to eat so much, but got to do what i can
gets to a point when ive eaten so much, i feel like 1 more bite will result in spewville population me.
I know that feel bro, but rest assured, it does get better.
As metabolism slows a bit and you gain the weight you're after it's easier to maintain it.
I took 2 years off gym and took up running and dropped back to high 70s which was still 10-15kg more than when I started, plus I gained the size/weight back easier this time around.
yea, was funny when I was 16-20 I barely put any weight on. Hit 21 and got to 66 in no time, from 21-24 (on and off training) have made it to 70. Now getting over that 70 mark has been the challenge.
I am thinking that I need roughly another 5kg of muscle and I'll be looking how I want to look, which is basically how I am now just bigger. But to reach that, I really need to sort my diet out so its a little more appropriate rather then just eating everything.
Thanks Leesh
  • 3 weeks later...
well first night back in gym after 2 weeks - uni and puppy along with work has taken all of my time
got to gym last night, dropped near 30kg on all my lifts for that particular workout. Hopefully it doesnt take long to get back to where i was.
yea, i wasn't overally surprised to be honest.
mentally i wasn't in the zone which i know impacts lifting
some regular time in the gym would be nice
If I had room at home, I would seriously consider getting a power cage with a decent bar and weight and some DBs maybe even KBs
It won't :) I was recently out for 6 weeks... In a month I'm back to where I was except in bench
really hope so, I think not benching as much as what i was 2 weeks ago put me right out of it mentally
just got to get back into the swing of things
The first night I went back after 6 weeks off I cried and left after failing bench. Mentally if you're not in the right frame of mind, don't bother. The next night I was better, but it took me about a week and half to get back mentally after the break.
I've had 2 weeks off before and it only takes a week or 2 tops to get back to where you were.
I have a process on how I come back from breaks.
If it's been a week my first session will be same weights but only 2 sets of the 3 on the first session, maybe also the second then full everything on the 3rd.
If it's been 2 weeks I'll drop a little weight and do 2 sets first session, full weight but 2 sets second session, then full weight full sets 3rd session.
I've done this a number of times as I make a point of taking week long breaks every now and then to recover small niggles etc. Always works a treat for me.
Failing really is a part of progress.
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
