Ok so I have that many random plugs that go no where in my car but this one is bugging me. Anyone know what its supposed to do? Im missing the plug off my standard oil pressure sender but it has 2 terminals where this plug only has one...
It comes out of the starter motor loom. Thanks in advance :)
https://www.sau.com.au/forums/topic/377524-help/
Hmmm, that's aftermarket.
You didn't say anything about aftermarket.
Location of standard oil pressure sender switch.
Plug exposed.
Connector exposed.
Standard RB20DET.
Can't vouch for RB25DET but from memory they're the same.
Edited by Nic_A31
https://www.sau.com.au/forums/topic/377524-help/#findComment-6020519
Oil cooler..
You mean sandwich plate... ?
The oil filter goes onto that, and it bolts onto the block.
I've got a standard one yes.
RB20 or RB25 ?
Is there a bolt in the block somewhere around there? Might have been plugged up.
It's around 10 o'clock proximity to the oil filter. Might have to have a feel around for it.
https://www.sau.com.au/forums/topic/377524-help/#findComment-6020556
Yeah crazy looking thing that the filter usually bolts onto, just convinced myself it was a cooler. Dont mind me haha
Think I found it, has a bolt plugging it up.
Would I be able to use that yellow plug just run an earth of the other terminal?
https://www.sau.com.au/forums/topic/377524-help/#findComment-6020570
  • 3 weeks later...
correct me if im wrong but that looks like the standard oil warmer from an rb25.. but seems to have a different sender in it i believe.
i just recently put my mates c33 back together with a 25det and it had that same loom plug but only single pin on the pressure sender.
https://www.sau.com.au/forums/topic/377524-help/#findComment-6047126
Yeah pretty sure I took the same thing off my other 25
I put the wire on the forward most terminal on the warmer thingy and seems to work like a normal on. Light comes on with ignition then goes off just after fire up. Thanks for the help guys :)
https://www.sau.com.au/forums/topic/377524-help/#findComment-6047382
    • Hey guys, Just want some advice on r34 GTT ac system. Since I’ve owned it, the ac compressor, doesn’t matter the set temperature or ambient temperature, runs for around 10 seconds then disengages the clutch, then re-engages everywhere 30 seconds or so and keeps repeating this.    is this normal?   I had it recharged today as it was slightly low and thought it would fix it but still does it. it cools fine in summer even prior to the recharge, except for the usual warmup when stopped or in traffic (still yet to wire overheat fan to on with ac)   any thoughts would be much appreciated
    • To plug the hole. The engine plant may not have known whether the car it was going into had a gauge or not. It was a long time ago and the integrations might not have been fully modern. Or they might not have cared because the extra inventory and processes to save a few cents on the sender might have cost more anyway. But please tell me you are not still confusing the idea of a pressure gauge sender, and an oil pressure light switch. The switch will be out there. In a separate hole. Probably with only one wire running to it. Running the light.
    • Blower needs to go low on the exhaust side, displacing the AC and PS, which you have to decide whether you want to keep and how and where to relocate if you do. Electric option for PS is, at least, helpful. Sadly, there is no workable 12V electric AC of any value. Whilst the blower is the last compression step before the throttle, and so it might seem a good idea to have it near the inlet manifold (as mentioned above), you probably want it to go through an intercooler first, so, having it on the opposite side of the car facilitates that air flow path. The turbo discharges into the blower, so proximity of the turbo's compressor outlet to the blower's inlet is nice. But then you might want to intercool that too, before boosting it again....which would probably be a ball ache. Routing pipes out to the front and back could be a bit shit. If there was room for (at least) a small (but preferably larger) water to air core on that side, then that would probably be the best approach. I guess a reasonable alternative would be to locate the blower where the alternator is (more or less, associated with the inlet manifold, per Matt's thought), and somehow incorporate a water to air core into the manifold, sort of like they do for modern blown V8s. The big difference here though is that those V8s have only the one throttle (upstream the blower) and only the one compression step (the blower) and no need for too much in the way of bypass/blowoff valves. Whereas in a twin charged 6, you do need to think about one or two bypass valves associated with the 2 compressors and you would prefer to have the intercooling done before the air has to pass through the throttle. You'd like the throttle to work approx the same no matter what the compression is doing. But if it is located in hot air stream before a cooler, then sometimes the air will be real hot, sometimes it will be quite cool, and the throttle mapping/response will be quite different between those two cases. The throttle, if sized for hot air, would be too large for cold conditions. It's all a ball ache.
    • Package SC on exhaust side. Remote mount turbo. Still a fair bit of room when you get creative on the inlet side of the motor too. Especially if you can get really creative with the welding, and effectively build it into the bottom of the inlet manifold. Would definitely take some design work, and some trial and error, to make sure flow works well still! Might be easier to just start with the Nissan March though... All the work is already done for you...
