Hey Guys, Ive finaly finished putting together my build and now need to set the PFC so i can get it to the tune shop. ive never played with a PFC before and to be honest a little scard to touch the hand controller lol
Ok its a R33 S2 GTSt and ive done:
Z32 AFM
Sard 555cc Injectors (denso 195500 2240)
Hiflow stock turbo
Tomi Pon cams
Greddy Profec b boost controller (run 10psi atm)
FMIC
Any Help would be much appreciated
Thanks, Dave
https://www.sau.com.au/forums/topic/377863-setting-up-new-pfc/
Basically to get it running to get to the tuner youll just need to select z32 afm and also set ur injector vaules which from memory for 555 it would 0.67 and .18 latency but check to be sure. Have a look at pauls faq for details how to do this all.
no matter what you do
run minimum boost
dont load it up
dont flog it
simple
with the basic z32 set and injector settings set correctly and default maps you should be ok
if in doubt, richen it up a little as an insurance policy
if you flog it, boost it up, trash it
expect it to go bang as you have changed quiet a bit
.18 is for the nismo 555s, sard/denso will be different.
as said though, select vg30 from the airflow list and scale the injectors to 67%. do a search around here and check pauls faq to see if you can find the latency figures for your injectors.
The ignition timing in the standard pfc (not tuned) is too much for 98 ron fuel. It will knock like hell. However it is not that hard to sort out and I'm sure you could fix it up with a bit of help. I have an ign map that you can put in and it will be fine. It works on my car with a stock turbo and I can run it up to and over 16psi without any significant knock. It has been proven on a dyno after I tuned it. However as your turbo will be putting out a lot more air than mine I would suggest that you pull 2 degrees on the temporary ign adjust and run it like that to guarantee no knock. Then when you know there is no knock leave it as is. Bear in mind that the temp ign adjustment will be reset every time you turn off the car. I can help you with the ignition timing but the fuel is not something that can be done over the phone or the internet. Luckily the power fc is rich as crap when untuned so you should be ok. BUT you have to get a wideband and check it BEFORE you flog it. Like it has been mentioned you car can go 'bang' very quickly if it runs lean and you are giving it shit for an extended period. You could break it in under a minute given the right conditions. To summarize, I'd repeat what Paul said. I'd also say put in the ign tune that I'll pm you (If you like) and then drive it to the tuner immediately to get it tuned. Cos the ign side will be mostly done, it will cost a lot less to get tuned. Read the pfc faq and make sure you set the idle up right. Hmmm...thats about it.
If the PFC is not brand new then it may have a tune on it. Init data first to ensure any old tunes are gone. Then setup the injector settings and set it to the correct AFM. Then what I would do is pull 5 degrees of timing across the whole map. Settings and then in ignition and set adjust to -5. Car will run like shit but should be safe enough to get to the tuner. Ive experienced a stock power fc on a stock car and flogging it lol. Det heaven.
Yes that is a good point. There probably is a tune on it already. In the pfc faq you will find everything you need to set up the injectors and afm. Just read. Although pulling 5 degrees across the board would keep knock away I think it is a bit drastic. Some areas actually need 5 degrees added to them.
isnt there a setting on the power fc that if turnt on and the car knocks, it makes the engine light flash
ive had that happen on mine one time..
yes, by default it flashes the engine light if knock exceeds 60, injector duty exceeds 98% or afm voltage gets close to maxxed. all 3 have a different type of flash.
Pfft. Dont be scared mate. You can plug it in and do the 30 minute idle setup, the afm change and the injector change and then drive it to the tuners. Simple as that. All blokes here are saying is that you could hurt it if you flog it untuned. When you reset the pfc it still has a tune in it but it isn't optimal. It wont blow up driving it there as long as you don't floor it. And as for putting it on a truck and towing it there that is a bunch of bullshit. I've pm'd you my number to talk you through the afm and injector changes you need to make. It really is a piece of cake when you know what to do.
EDIT: http://injector-rehab.com/shop/lag.html
Edited by Room42
ok so i have now setup the PFC with thanks too Nathan (Room 42) for like an hour of his time
injectors 66% latency .034
VG30 AFM From the menu
did the 30min run a/c on ect. but it rough as guts and seems to me like its only running on 5 cylinders. gave it a little slow poke to 2000 rpm and there was no change up to 2000rpm. a mate sugested that it may be the AFM but i get a reading on the pfc
PFC displays this :
InjDuty 2 %
IngTmng 17 deg
Airflow 1415 mV
Eng.Rev 890rpm
BatVolt 14.2
Knock |
Wtr Temp 48'
also i had the injectors tested before i installed.
Yeah running very nice ans smove now turns out the wires came out on the 6th injector. i can do amazing things when i actually open my eyes. :P
so now i wanna reset the PFC and do the cold start run again. do i just disconnect the battery and push the break or do i need to reset the PFC somehow????
Hey man cold start is different than the 30 min idle learn that you do first off. To reset you go into etc and its in there somewhere. You initialize the pfc. Unplugging will do nothing. Then you will have to put in the vg80 afm setting, the injector settings and then start it and do the 30 min idle thing. I have got away with not doing the idle thing and it makes bugger all difference. Up to you. I cant say it enough tho man as tempting as it may be dont give it a hiding until its tuned. I've pm'd you the ign map.
Cold start is setting the water temp in the settings. You add or subtract fuel by increasing or decreasing the numbers in there. As it isn't tuned the numbers already there will do the trick for now. When its tuned ideally you dont want any numbers in 50 or 80 degrees so the tune stays more stable. Dont make it zero yet as you will have to change the fuel map significantly to compensate for this.
the standard pfc cold enrichment figures are spot on, dont touch them. the only reason you should ever set the 50 degrees value to 1.000 (you have to have numbers in there...) is if your full running temp is significantly less than 80 degrees, which is pretty rare.
Mine runs at 70 degrees. Sometime gets to 75 in traffic. So my 50 and 80 are 1.000. When I say zero I mean 1.000 cos there is zero correction.
Edited by Room42
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
