Hey guys contemplating selling my brand new Varstoens as plans have changed with the car.
4x brand new Black 18x9.5 +12 $1400
with brand rotalla 234/40/18 tyres. $1700
also may be interested in trades for Uras NS 02, CST Hyper zero or Cr Kai in 17x9 or 9.5 +12 -> +17
located in sydney
cheers
Edited by ti2l
https://www.sau.com.au/forums/topic/378721-varrstoen-221-18x95-12/
hey man not trying to be a dick but you can get these brand new off Rota Oz for $1095 might want to ajust the price :)
ROTAs look shit compared to these , Varrstoen are the nearest replicas you can find . Yes your a dick
Varrstoen are the best looking TE37 replica's available. I personally only buy genuine, but if you want the TE37 look without the price (and don't mind not having light weight wheels), then these are the best ones to get.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
