would be cheaper to buy the Vossens though...Vossens and all the other brands are just replicas of the BBS above. Plenty on Ebay.
thx. I had no idea the vossens were copied off the bbs whhels.
The way they advertise each of their wheels and the responses from everyone on myg37.com you would think they had come up with the original design.
Really? The split spoke and mesh spoke designs were pioneered by BBS; basically everyone who's done it since has basically been copying them.
Tempe sells a copy in 19", but I've got no idea what the offset is. Probably shithouse, being Tempe. But you could buy them and respray them.
The DTM 073 is also another copy.
yeah!
on myg37, it would seem like a sin to have rims that aren't vossen. lol
having said that, the concave CV1 and CV3 look epic
yeah I've just started to look into wheels. Before this I've had little to no idea about wheel brands.
Interestingly a lot of the e90 M3 drivers are using the copies. I thought they would have had the dough to buy the originals or couldn't bare
to be seen with copies.
Just because you've got dollars doesn't mean you've got sense.
A significant number of modern M3 owners couldn't give two shits about owning one of the best handling coupes in the world, they just want everyone to see them driving it. That's why the current M3, with its giant V8, specific exhaust and body, and luxury trim, is a complete kick in the balls to the small I4, stripped out, barely noticeable from stock E30 M3 that started the legend.
Now that they've blown so much cash on a car they will never truly appreciate, they're too cheap to spend up on accessories whose performance means even less to them than half the gadgets in the car, or the spirit of the original. Its quite easy to tell that a badged 320CI isn't an M3 these days, but most people wouldn't be able to pick the VMR 710 from the BBS CH. For them, that's more important to the handling benefits from stiffer wheels and less unsprung weight.
Haha true that, same goes for the Merc's AMG C63 and similar models. Bought to be noticed but if you want something as simple as keyless entry (which should be standard) that's an extra $2k on top of the already $150k you're forking out!
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
