C'mon be fair guys, I can imagine the cars you all drove around when you were 17 werent incredibly tasteful or well modified. Besides which if you lived in Maraysia affording anything other than a Proton is a bit of an ask.
Jash
Ok I don't get a few things on one page he sez "Have a closer look to stock intercooler" then on a few pages later he sez "
no need to add the additional boost meter,gauge meter etc because my car is not turbocharged" he is confused me thinks.
Enkei model wheel 14x8 on 185/70 Goodyear Eagle GA,I don't think 185's would strech over 8inch rims and they dont look 8inch.
"It's obtained in year 1993 and the stock one colour is metallic blue , but after 10 years later i've no idea to have to painted my car to Metallic Brilliant Silver because of my original paint is gonna "die" and cause many stain at my car body , after the paiting job which cost US$ 1500 , my car is looks like a new one"
What the f#ck is he goin on about??
how he has had the car for ten years and now the paint is thrashed. it was originally blue but he painted it.
I'm with Jash on this one. Ive seen much worse abominations around the place. it's not a GTR vspec (I did giggle a bit on this one) but it's still a pretty tidy car.
it's a million times better than any of the ten thousand SSV lancers getting around.
he should compare it to a nissan cefiro, at least they ahve something in common (and yes the A31 ceffy was sold in malaysia sporting the worlds most wierdest RB engine an RB24S... inline 6 carbed engine rated at 141HP, sold as a nissan Altima in Malaysia back in the day
Funky Monkey - Do I need to remind you of how much an A31 is worth in .my? Last I saw a decent one was like RM50,000 - around 20k AUD, That little Proton'd be worth about RM5,000. The dude is a little confused yeah, but he's working with what he's got available, as you do.
Jash
PS I would have gone for a Perodua Kancil personally.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
