Hi guys,
I am wanting to get a different BOV but i want the flutter sound valve not the typical whossshh. What are the names and models of any flutter sounding BOV's that you guys know of. And if any of you have one are you willing to swap for an HKS BOV?
your help is much appreciated,
Thanks
JL
https://www.sau.com.au/forums/topic/37919-bovs/
I never knew u could buy BOV's which make the flutter sound
ive got a factory bov with an fmic and i get the flutter....pretty sure its only the fmic which makes that noise
Or by removing something around your turbo so air hits it harder or against the wastegate ??? which creates the flutter...
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763682
shouldnt cause to much damage
thats same sort of principle for VLs when they wake on a cooler and get flutter
my turbo is still in good nick and thats running some high boost as well
but then again stock skyline turbos r made from pottery clay :-p so i wouldnt really risk it..
nick lets test it on urs :-)
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763750
Get a BOV, plumb it back, and get performance out of your car.
I think he's more concerned about the noise his car makes rather than the performance of the thing. :D
runnning no BOV hinders performance... u serious??? haha
Dead serious...... what are you laughing at?
:slap:
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763838
*sigh*
well from memory a BOV unless running high boost is not going to improve performance on anything... infact im pretty sure in one of my speed mags where they had a 4 page spread on them and what they do they are only designed to release pressure to extend the life of your turbo.
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763900
Guest
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
