question still stands can i use tomei solid lifters with 9.15mm lift cam ? if i get some yesses or no's i can look into something different or purchase..
No, you wouldn't use them as you dont have small base circle cams.
They are suited to 'Tomei' cams with more than 10.25mm lift.
So is there a aftermarket lifter to use with a 9.15mm lift cam?
Not required... The smaller lift camshafts use the same base circle diameter as the factory cams. In other words they are machined 'the same'. So they are not required. Just make sure they are in good condition and you have adjusted the valve clearances correctly.
I would be wary about the ramp rates being 270s, maybe a little more spring pre-load you could get away with them
But with 270s you would want to rev a 25 pretty hard to take advantage of them, or is it for your 30?
well you're handy on the spanners, give it a go, not a big job to pull the cams back out if it floats
Off the top of my head all the 270 results ive seen had springs, but they all had more lift than what you do.
p.s didnt you score some camtech 272s a while back? (was flipping through an old Zoom mag yesterday)
  • 3 weeks later...
Correct term is 'under bucket shim' (and there is 'over bucket shim' & 'solid bucket')
Rb26 clearances - 0.018" ( +/- 0.001") intake & 0.015" exhaust ( +/- 0.001")
Measure with feeler gauges when the cam lobes base circle is above the bucket
Face valve/ cut seat/ order thicker shims to close the gaps
Machine tip of valve/ shim to open
Too loose it will rattle and cause premature wear
too tight it will stay open causing loss of compression
I've had to machine a 26 head out for poncams a couple times
try reading the whole thread
