question still stands can i use tomei solid lifters with 9.15mm lift cam ? if i get some yesses or no's i can look into something different or purchase..
No, you wouldn't use them as you dont have small base circle cams.
They are suited to 'Tomei' cams with more than 10.25mm lift.
So is there a aftermarket lifter to use with a 9.15mm lift cam?
Not required... The smaller lift camshafts use the same base circle diameter as the factory cams. In other words they are machined 'the same'. So they are not required. Just make sure they are in good condition and you have adjusted the valve clearances correctly.
I would be wary about the ramp rates being 270s, maybe a little more spring pre-load you could get away with them
But with 270s you would want to rev a 25 pretty hard to take advantage of them, or is it for your 30?
well you're handy on the spanners, give it a go, not a big job to pull the cams back out if it floats
Off the top of my head all the 270 results ive seen had springs, but they all had more lift than what you do.
p.s didnt you score some camtech 272s a while back? (was flipping through an old Zoom mag yesterday)
  • 3 weeks later...
Correct term is 'under bucket shim' (and there is 'over bucket shim' & 'solid bucket')
Rb26 clearances - 0.018" ( +/- 0.001") intake & 0.015" exhaust ( +/- 0.001")
Measure with feeler gauges when the cam lobes base circle is above the bucket
Face valve/ cut seat/ order thicker shims to close the gaps
Machine tip of valve/ shim to open
Too loose it will rattle and cause premature wear
too tight it will stay open causing loss of compression
I've had to machine a 26 head out for poncams a couple times
try reading the whole thread
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
