hey all, my turbo is starting to get a bit of shaft play and puffs out smoke every now and then.
now my question is, is there a rebuild kit or core replacement?
i dont want a hi flow turbo, its cheaper to buy a new garrett than getting it high flowed anyways. so no interest
i want my turbo to stay stock. i dont mind getting a core with steel wheels either if that is an only option.
if anyone knows where to get one from or part numbers, i would greatly appreciate it.
i prefer not to buy a 2nd hand one, because the same thing will happen again sooner or later.
so recap, stock turbo rebuild kit. that is all
cheers
Jean
https://www.sau.com.au/forums/topic/379507-r34-turbo-rebuild-kit/
Don't know if there is a rebuild kit for stock turbo.
You're better off buy hi-flow or new Garrett turbo really. I know it isn't what you want but there is a reason for no rebuild kit for this sort of turbo (limited market I'd imagine).
ok, just a random update, ive found somebody who claim they offer new cores for the R34 turbos, with 360 thrust bearings or 270 bearings.
but on another side note, i just replaced my stock turbo with another stock turbo, both OP6 turbos, so from a neo engine.
the one turbo i got from a r34gtt had a black front compressor wheel and when i took the cover off, felt kind of like plastic, so i was thinking that flimsy plastic ceramic crap that people claim the turbos have.
NOW the interesting part, when i swapped for my other turbo, came off my "stock" stagea, i took the front housing off that turbo and to my surprise, its a steel wheel!
R34gtt turbo= plastic wheel, fins bend under a bit of pressure
Stagea neo turbo= steel wheel no flex what so ever when putting pressure on the fins
So my question is, where there any revisions in the op6 turbos? from ceramic to steel wheel??
the stagea turbo just had major shaft play from being over boosted accidentally, (17psi) that why the replacement.
both turbo wheels and dimensions are the exact same, no highflows or rebuilds!
im very confused.....
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
