  • 1 month later...
Thanks guys, looks like ebay's the go...tronzstagea which bulbs did you get? the bulbs from hong kong?
also jaycar sell burners, they have conversion kits, not sure if they sell D2R/D2S though, but worth a look if youre near one
Hey just thought I'd let u guys know.. I sell H.I.D kits and I can get these globes for u if u or anyone likes.. I have a set in my V if anyone would like to have a look.. Have had them in there for over a year and still going strong..
I anyone is interested PM me..
Globes come with 6mnths warranty and are available in 4000k, 6000k, 8000k, 10000k
