Basic map of RB20 is tuned for Jap fuel which was pretty much always better than 95 RON. Running on local 91 will almost certainly see you running on the knock maps, which are quite a bit richer and retarded than the normal map, and it will be a slug. And it will probably still ping, especially in summer.
https://www.sau.com.au/forums/topic/379946-rb20-on-91-fuel/#findComment-6059430
It might be possible it will chew through more fuel when running 91 running on those said knock maps, than 98.. even on 91 I wouldn't dare go up a hill or put any kind of load whatsoever on the engine (even beyond 4000rpm on a level road)
https://www.sau.com.au/forums/topic/379946-rb20-on-91-fuel/#findComment-6059521
I have run 91,95,98 and some other crap with 98 to make it higher octane. At the time I had a stock turbo and a power fc. Basically with running 91 I had to take out about 6 degrees from memory so it wouldn't knock. It wasn't a hell of a lot slower but it was still fairly noticeable. Considering there is only a 5 dollar a tank difference between 91 and 98 when you fill up, you should use the good stuff.
If you have a stock computer definitely use 98 or better.
https://www.sau.com.au/forums/topic/379946-rb20-on-91-fuel/#findComment-6059779
yep, if you tune for it (or remap for it) its fine
but it will be sluggish and youll be limited to a low amount of boost
so if you are ok with that, go for it
but imho it would be pretty dull and sluggish
https://www.sau.com.au/forums/topic/379946-rb20-on-91-fuel/#findComment-6059893
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
