oh mate thats not fair! I will definitly keep my eyes open for u. All these thefts are convincing me more and more to stop being a tight arse and get a decent alarm/immobiliser. did u have an alarm fitted?
Ignoring the plates - does this look like yours?
It was found burnt out in Logan today :(
Updated with extra photo. It does look like yours.... Ill find out where abouts exactly in Logan it was found.
Wholy shit - That is friggen shocking.
Even though that car looks exactly like yours, even the wheels :( Lets hope for the best. I can't believe all of that could be done over night.
One of the workers at Nut and Bolt factory has his 32 stolen last week. Same thing....burnt out and dumped at logan. Apparently a young guy driving around in a stolen purple metallic 33GTST is to blame, also I was told Police know who it is and are looking for him. Could be the same guy. He stole it from the Hyperdome.
They have his face on CCTV buying the petrol IN the car that was stolen right before the car was found burnt out. So he's f**ked if they get him. I would contact logan CIB to see if it's your car
They've either changed the front bar or it's a different car.
False. You can see the screw holes and change of paint shade from the mspec front lip that "was" on there.
Must note. Very sad for your loss mate. This is partially the reason i dont drive my car out so much anymore :(. Well that, popo and fuel.
Thanks a lot guys. Sorry, I wasn't around for a few days. Yes, that is the car, unfortunately. Had an alarm with an immobilizer but no one heard anything. I removed the mspec front lip, cuz it was a bit broken and i was going to fix it. Police came and tried to find some finger prints but they couldn't find any.
Thank you so much everyone, and special thanks to V8skylineMAN for the pictures and special effort to take care of the car.
Hey guys...
Friggen sucks having the car stolen, I know as mine got nicked last week.
Just wanted to let people know that apparently there has been a rise in skylines stolen lately. I just got off the phone with the police about it. So if you dont have secure parking I would really recomend getting a really good alarm
This is getting wayyy too close to home. And you, majority of these cars (and others) seem to be being stolen by late teens to early 20's, thrashed, then horribly mangled.
So sorry for your loss. Hope you had insurance and it is honored.
