hey guys up for sale is my white 2000 model r34 4 door.
have only owned the car for approximately 8 months but another car has come up for sale i basically have to have so letting this go unfortunately as i cant rep 2 cars.
has been an awesome car since ive owned it however and it will be missed no doubt.
car is turbo and manual! none of this NA auto bollocks
124xxx kms serviced reguarly ( as close to 5000kms as possible)
only a few mild mods, mainly cosmetic.
mods include:
-nistuned computer tuned to 181kw on 8psi (claim by previous owner)
-splitfire coipacks
-origin roof spoiler
-nismo lip kit ( looks the tits, so much more aggressive than stock front bar )
-eyelids
-gunmetal grey rota grid-r's 18x10 +15 rear and 18x9 +20 front. fit wicked, have a perfect amount of poke out the guards, tough fitment
-3 inch dump pipe to 2.5 inch catback (unsure of cat)
-removed spoiler (just taped over holes, was going to weld over and paint etc but selling now so not bothering)
-custom intercooler piping done by AM performance
-pod filter and blocked of BOV for da flutterz
-smoke front and side indicators
-debadged boot
-lowered on some springs of some sort (not entirely sure what they are but theyre a pretty nice ride and high enough to not draw po po attention but low enough to look tough)
-ebc green stuff brake pads done about 5000kms ago up front
-top of the range alpine speakers
-manual boost T (only clicked to stock 8psi except for special occasions)
-aftermarket guage setup (boost, water temp and oil temp which is yet to be installed, as was waiting to be serviced)
thats about it off the top of my head.
asking $16,500 o.n.o i know this might seem steep but regular run of the mill silver na auto 4 doors all sell for 13-14 so a couple extra grand for a white turbo manual one is fair i think
if i get my asking price of 16 i will throw in some SARD 550cc injectors and a highflow r34 neo turbo with op6 housing. setup should be good for 250kw easy with z32 and a better fuel pump
contact on 0430928476 can send pics via mms
located in barossa valley SA, but can travel to adelaide for buyer if theyre serious
Edited by changeofplan
https://www.sau.com.au/forums/topic/380271-r34-4-door/
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
