Like i said im new to skyline so obviously my knowledge level is low....my mates mechanic can do it for me for no cost just depends how much or what gearbox it is and kms only done 75,000 on the clock so it is a good deal!..:)
  • Replies 71
Posted Images
All skylines odometers are wound back how would a car that's nearly 20years old only have 75000kms
Your mate probably wound it back
And the conversion is still gonna cost close to $2000 for all the parts needed
What do you mean or what gear box, the only option is to put an rb25 gearbox in anything better will be more expensive and anything cheaper won't last as long
Edited by stig mick
Wow what an effort of putting the pic up that shows initiative and FYI im using a smartphone so its quite hard typing down especially with a fat thumb and at work at the same time...sooo childish of yous did not expect to hear that from a 26 years old...ermmm and im new to all these as my profession is in Finance Industry not in mechanics :)
you dont have to be a mechanic to know
1. thats cars ugly
2. auto's are for poofters
3.your getting ripped off
+ 1
christalmighty what an ugly piece of shit. It looks like someone tried to turn it into a prelude...
"Don't build what you can buy" just buy a manual Skyline... and FFS... buy one that hasn't had a "Queer eye for the Leb guy" make over.
The only way the Kms on that car would be genuine, is because no one drives it for fear of being seen in public in that horrific rolling turd.
:rofl2:
180fwkw prelude that weights 1200kg? that would be FAST.
4th gen onwards weighed 1300kg+
R33 GTST is 1390ish so there's not a whole lot in it. The 33 would make mountains more torque too, and being a rear driver wouldn't sit there trying to tie itself in a knot with torque steer.
The 33 would flog it.
And +1 for that car being f**king ugly. All it's missing is lambo doors and you've got yourself a real Lebo Chariot there.
is 4th gen the last one?
If so then the car I'm talking about would have close to 1500kg with all the fibreglass, sound equipment and the fully sick 20inches chrome wheels
So it would have handled and accelerated like a truck
I work in finance, too, but I still know a horrible bag of arse when I see it, and when I look at those pics you posted I'm looking at a horrible bag of arse.
It is a fugly POS. Autos are f**ked. They are fat and slow. The bodykit is an abomination. The stripes look like red gaffa tape. The lights look like someone flogged them off an Audi and glued them on.
It's truly f**king horrible. Anyone who tells you otherwise is either blind, hates you or is a Lebo. Either way, they should not be listened to.
Gen 5 was last and weighed 1380kgs.
agreed
it just gets worse and worse it was a 5th gen i just googled it
i even found a pic of the actual car i remember the number plate
http://www.flickr.co..._05/5253967954/
Edited by stig mick
agreed
You know what's feking hilarious? That Prelude looks better than the 33 in question.
:rofl2:
That's really saying something.
100% sure, the bugger cant seem to drive manuals lol. Also the other profile just coped a ban, hence new one.
coming to the bbq tomorrow?
i wanna say yes but i am poor beyond a joke
i feel bad turning up with nothing and i cant even afford a 6pack of shit beer
:rofl2:
yeah i'll have to agree but if that was for sale it would be a touch over $7500 even with the 249000kms on the body it currently has
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
