no its a stupid idea....2k will get you some really nice wheels..painting the stockies black will just look like exactly that..stockies can look ok if you lower your car right and put some spacers in so they fill out the guards a bit better..painting them a diffferent colour rarely makes them look any better..usually worse
you dont have to spend 2k on wheels anyway..full set of rotas can be had for 1k and look the business or, learn to ebay.
Just remember Stance is more important than rims..putting 2k rims on a car that isnt lowered right will just look like ass and you would be better offf with stockies..
Arts get off ya high horse mate.
Op- there is nothing wrong with painting the stockies, its a great thing to do, especially if you are on a budget. Make sure you take the time to do a quality job tho. If done rite it looks fine, but at the end of the day they will still be stockies. It will be fine until you can save up enough to get some good quality after market ones.
Good luck
Adam
They did so much wrong it's not even funny, I bet their paint is cracked and peeling now.
I dont see what they really did wrong...its like 4 simple steps. I basically did the same thing and my wheels are still freshly coated with clear after almost 8 months.
They didn't chemically bond the layers, and they didn't show or mention any mechanical bonding either, though they may have done that off camera. At 8:03, that spraying technique is terrible, he is spraying like a 14 year old graffiti artist. The other bloke has much better control and technique using the gun.
what do you mean by chemically bonding the layers?
When you spray, you shouldn't let the paint dry between layers. If it does, you need to sand it back to create a rough surface for the paints to mechanically bond. This will never be as strong as a chemical bond, which is where you let each layer dry to a tack before spraying the next layer. This means all the layers will dry together, creating a chemical adhesion that is much much stronger than just a mechanical interlock.
Back on my High horse here but....
it can look ok if you paint up some GTR rims or something and they are painted PROPERLY...
but painting the standard rims black looks shit..if you have shit rims to begin with painting them black will NOT solve the problem, they will still look shit..
now dont get me wrong it is ok to have standard rims as it keeps your car looking stock which is cool, but painting them black is not making it look any better at all, unless maybe your car is black and your trying to be super stealthy...:ninja:
they say you cant polish a turd and while you can paint one, a painted turd is still a turd
I've seen black stock rims on a white car which looked good, I've got silver stockies on mine which I'm happy with for road use, stock rims are good for a lot of reasons.
Paint them black, doooo iiiiitttttt
+1 ^
Artz, I don't know what you're on about mate. Standard R34 GTT wheels are not baaaad looking, they may not be as eye catching as a nice set of Jap wheels but they still go alright. Especially when painted black. When they are unpainted they look like standard wheels. When they are painted, they do a good job of setting the car off.
I mean this:
Compared to this:
It's a no brainer.
I agree with Hanaldo on this, makes the job much nicer.
If the paint on the rims to begin with is alright, then u dont neeed to primer them then paint them as such, if u use a light grade scotchbrite and scuff the wheels up and give them a good coat of paint (2-3 layers) then that should be easily suffficient. havent had any problems with doing that (and thats been on the bodywork of my old skyline which lasted me a year with no issues what so ever)
Just my 2 cents :thumbsup:
+1 ^
I mean this:
Compared to this:
It's a no brainer.
Perfect example. Seeing the difference is almost motivating me to do mine :blush:
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
