That's the thing about the precisions if you want low boost you can if you want big #'s turn it to 35psi. Why limit yourself with thr 6262for 4-500rpm.. On supra forum there's a good guide on how to make the stock auto live with big power.. If you stick to the same rules as the guys with built stock auto running 8's in full weight supra it should handle high 400rwhp ok.
  • Replies 203
Cheers for the info, I'll have a few drinks tonight and Sort it all out.
Just came back inside after fitting the exhaust manifold....an angle grinder was used lol
but its all fitted up :)
pics of my grinding work to come lol
Hmm crappy pic...but the only one I took today and there are not any photos on this page yet.
Used the T78 to mock up the intake pipe, had some 3/4" push lock hose laying about so removed the funky 180deg metal heater hose bend (gives me more room and looks neater (see earlier pics of said funky 180deg metal thing lol)
Painted the intake pipe with gloss black engine enamel, and went to paint the coil pack cover thing the same but, got one little spurt of paint from the can and it was empty...So now I have 1 big black spot on it..... >_< Will finish later.
Forgot to get pics of my epic angle grinder attack on the manifold so will do that tomorrow....If I remember. Going to marques in the park for some inspiration.
Nate I see you reading, come say hi (and give me your wheels lol)
Lol, should i drive up to canberra for you to help me out with the signal stalk problem?
nah, i'll sell this thing, the moment i fix something, something else goes wrong, i'm so over this. Might get into a vvti one day...
Lol, fixed the indicator issue already, i found a 10amp fuse where it was supposed to be 15amps. what a goose, that previous owner. how did it manage to survive this long however, i have no idea. the fuse that is.
car will be going on carsales, next week.
yeah 6262 with a twinscroll .84 A/R rear on it
should just touch 400rwkws with a set of drop in cams on the 1JZ at 30 or so psi and E85
even if it doesnt make 400 the area under the curve will be a lot better
hahah, was it in the absolute pain in the ass fuse box by the accelerator pedal?
I hate the one!
Everything should have been in the neat one under the bonnet
yeah, even asian sized me, i knocked my head on the steering wheel twice. you want the whole conversion kit? 2.8k its yours.
=x
nah people ask silly money for 2nd hand torsen diffs...will get a TRD 1.5way for similar $$$
will have a surge tank and 2 x 044s, ECU wise I have no idea at this stage but leaning towards the Adaptronic E1280S
will cross that bridge when I come to it I guess
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
