If you have any idea how the inside of an engine works, you'll understand that staying constantly near or hitting the limiter is bad. Actually it's really bad.
The higher you rev the engine the more rod stretch you're going to get. While these rods are bouncing all over the place, add some crazy ass cuts all along the crank and things are going to get all out of balance, at such a high rpm.
Now hitting the limiter isnt bad if you do it every now and then, but inexperienced "drift queens" that just want to slide think its cool to just hold it on the limiter, and it's kind of like these clowns that have a vent to atmosphere bov - they do it because they think it's cool.
Well, unfortunately no one cares about your bov or your coolness at hitting the limiter. They just want to see it blow up, hence why they encourage you. It's human nature to want to see things blow. . Also, if You bash the limiter you're going to show that you have no idea how to properly drift, to the people that actually can.
Learn throttle control, and learn about what limiter bashing all day long will do to a standard rb25. Their rods are weak. They are more prone to rod stretch and will not take abuse.
I swear the questions on this forum are getting stupider every day.
has anyone seen a rod failure in a 25?
I bent a rod in mine but that was due to bearing failure welding the rod to the crank
All I've ever seen is detonation, bearing or oil pump related failures.
Never see a rod on its own let go with something else failing first.
Not very many engines like limiter bashing at all. When you limiter bash, you hammer the oil pump, when the oil pump cracks, you lose oil pressure and trash the motor...
I can tell you this from experience...
Yes, dead standard RB25 bottom end, making 370odd RWKW... Nitrous Oxide was then added...
Here is a look at my hand controller. Its a stock internal rb25det hitting almost 8200 rpm at about 26 to 28 psi through a gt35r. I raised the rev limit to 8500.
The youtube clip is uploading now and should be ready in half an hour.
I took it a bit easy in first gear to prevent limiter bashing.
I guess another degree of timing can come out at the high load 8000rpm cells.
Maxing your afm out, does that make it hard to tune?
I haven't tried it myself but I have heard that you guess what the timing and fuel will need to be after 8k and then change the 8k cells so the extrapolation works it out. I could be wrong.
That was the one and only time that engine will see that amount of rpm. The power fc lets you tune to 8k rpm anyway.
I'm about to upgrade my ecu to a map sensor based one so the afm maxing out wont be an issue.
ouch...would hate to see the EGT's
not that timing can be related between RB's due to the cas being a hunk of shit
The missus was watching the afr gauge and she reckoned it was mostly low 11's and went to 10.7:1 after 7500ish
Edited by Room42
There was a really nice piece of kit someone was using on here, individual cylinder EGT probes, basically comes with a special gasket that they are part of. Wasn't cheap though, something like $1500 for it and the data logging hardware/software it came with.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
