unfortunatley not Andrew lol
that really needs to be laser cut, then CNC milled from the look of it - though im tempted to get the file for the 1uz to T56 file and see what their machining options are, i do have contacts for all this stuff now.
even if the laser cutters did the main work then etched the surface for the milling part you could spend some time doing it manually on a mill.
  • Replies 87
The turbo has bolts atm, would like to keep that if possible....as for the dimensions to the outside...it doesn't really matter, but I would like the center hole for the pipe to suit 3" mild steel pipe rather than 81mm
Chris, go to 10mm plate is what i've been advised by all the exhaust guys.
They see warping issues after use with 5/6mm stuff.
As for gearbox adapters, why the T56? It's a clunky as f**k gearbox. If I could have easily, I would have avoided using it altogether with my LS1 and stuck with the 5Speed.
If you've got a Toyota engine, get the V160 Box.
just did some measuring on matt's old dump pipe (same flange) it is 12mm from the centre hole to the edge and 10mm bolt holes.
Did notice though that his piping is 76mm OD...so not sure what to do there as I think 81mm will be too loose?
V160 = $4500-5000 2nd hand
T56 $1500 2nd hand
Chris
If I ever feel rich...would you be able to do one of these?
http://www.ebay.com....=item2eaded1639
i bought the 1uz one yesterday - turns out its 3 pieces for the 1uz and they recommend steel - so i'll be cutting it out next week :P
lucky we have some 12mm plate lying around :D
yeah exactly
hardest part is going to be welding the pieces together without the 12mm plate warping - might have to bolt it up to the bell housing and weld it bolted up and low heat as its under compression so doesnt have to be a strong weld.
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
