unfortunatley not Andrew lol
that really needs to be laser cut, then CNC milled from the look of it - though im tempted to get the file for the 1uz to T56 file and see what their machining options are, i do have contacts for all this stuff now.
even if the laser cutters did the main work then etched the surface for the milling part you could spend some time doing it manually on a mill.
  • Replies 87
The turbo has bolts atm, would like to keep that if possible....as for the dimensions to the outside...it doesn't really matter, but I would like the center hole for the pipe to suit 3" mild steel pipe rather than 81mm
Chris, go to 10mm plate is what i've been advised by all the exhaust guys.
They see warping issues after use with 5/6mm stuff.
As for gearbox adapters, why the T56? It's a clunky as f**k gearbox. If I could have easily, I would have avoided using it altogether with my LS1 and stuck with the 5Speed.
If you've got a Toyota engine, get the V160 Box.
just did some measuring on matt's old dump pipe (same flange) it is 12mm from the centre hole to the edge and 10mm bolt holes.
Did notice though that his piping is 76mm OD...so not sure what to do there as I think 81mm will be too loose?
V160 = $4500-5000 2nd hand
T56 $1500 2nd hand
Chris
If I ever feel rich...would you be able to do one of these?
http://www.ebay.com....=item2eaded1639
i bought the 1uz one yesterday - turns out its 3 pieces for the 1uz and they recommend steel - so i'll be cutting it out next week :P
lucky we have some 12mm plate lying around :D
yeah exactly
hardest part is going to be welding the pieces together without the 12mm plate warping - might have to bolt it up to the bell housing and weld it bolted up and low heat as its under compression so doesnt have to be a strong weld.
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
