hey,
Ive noticed that when the car hasnt been started for a while ( atleast 3 days) that it will run a bit ruff and shaky for about 20seconds,( exactly like when you give a wipper snipper too much choke and it starts up all shakey then comes good)
Does anyone have this happen? If driven daily it doesnt do this.
https://www.sau.com.au/forums/topic/381072-quick-question-on-cold-start/
how old are the plugs? if old, then try replacing them. also, next time you let it sit for a little while, try letting the fuel pump prime for a few seconds before you start the car (turn the key to ON, let it sit for a few seconds, then turn it to START).
it may also be that your injectors are a little dirty and could do with a proper clean (remove and have professionally clean, not just a bottle of injector cleaner). might be worth changing the fuel filter as well.
final thing is, how old is the fuel in the car? if the car doesn't get driven much, and so the fuel is a few months old, then that won't be helping the problem.
plugs would be about 10 000kms old
usually let it stop its priming so 5seconds, it primes again when the key is turnt ( must be normal)
Fuel filter is 5000km's old
fuel is one week old so fresh, it was being driven daily then was not started for 4days
if driven daily or every couple of days it will start without the symptoms, but ill replace the plugs, filter again and injectors will be replaced in a few months
cheers for the input :cool:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
