Hey again Guys, have another GTR bar for sale.. Complete package or will separate, so if you need just the Lip or factory Mesh then shoot me a PM or hit me up back here.
It does need a little bit of work as the paint is pretty average so would need a respray, though seems to be all in good order still bar a few minor spots..
Will have some pics up soon, is Genuine & pickup is from Sydneys West, NSW.. $400 complete or make an offer on pieces ( Bar / Lip / Mesh ).
Matt
https://www.sau.com.au/forums/topic/381389-gtr-bar-lip-mesh-r32/
PM's sent!!
Hi mate, will have some pics up soon.. Just have to get some as it's at a mates house like most of my stuff lol. Have been moving interstate so yeah, sh!t everywhere at the moment.
Cheers, Matt
Ok, here are some pics of the Bar, Lip & Mesh... The Mesh is in Excellent condition!! No Damage, bends or breaks!! Nice & straight, very rare condition & sort after!!
The Bar itself is in pretty good condition, but as stated bar a few spots. It needs a re-paint due to some flaking from poor prep work prior to being reprayed some time ago & one of the corners that bolt up under the Gaurds has broken off.! Though its only a small bit as seen in the photos so shouldnt be too hard to fix at all.. All the Tabs are in good condition, no breaks & once painted up it will be a very nice bar in deed!!
Lip, not too bad. All Tabs are in good condition as well like the Bar, & looking front on & down below its in decent condition in deed. But, underneath on the corners its been rubbed away from general driving & is starting to miss its plastic peel over! If you look at the pics you'll see what i mean, but this does NOT take away any of the looks what so ever when fitted to the car & resprayed!! You cannot notice it once its fitted as its underneath the car & does not affect its structor or capability for fitting.. Its nothing major to really be concerned about, am just being honest as its not immaculate & would require a bit of glass for a 'show car'..
Anyway, check it out & first in best dressed gets it, or gets whatever part they need!! Thanks Guys, regards :action-smiley-069:
Uploaded with ImageShack.us
Yeah mate, still for sale!! The Mesh is sort of on hold at the moment, am just waiting for the funds. So Bar & Lip are still available!! Have had many inquires about the two but no solid payments as most have been interstate.. Cheers guys.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
