RB20DET minus turbo + custom ecu + standard ecu + loom Engine has done 125,000kms $400
Garrett GT2860RS Turbo + manifold and oil lines, used: 1 happy lap up and down the street. $750
600 x 300 x 75 Intercooler $60
Custom made plenum from Rotorua Imports. $300
Gearbox Exedy Heavy Duty Clutch Nismo 2600lbs Pressure plate and custom made lightened flywheel $550
Parts in sydney
PM or sms 0413 475 457
Edited by HGS130
https://www.sau.com.au/forums/topic/382037-rb20det-parts/
  • 3 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
