THE LAST DECA OF 2011
Sat 19 November
And once again we ask for your assistance
For this event to SMOOTH on TIME and SAFELY we need a small group of volunteers (OFFICIALS) to help
out in 3 sections in the morning and 1 in the afternoon.
All Officials on the day will be supplied lunch and drinks and go into the draw to win 1 of 2 BP fuel cards..
An Officials breifing will be held before the drivers breifing. So all Officials will need to be at
the Shepparton DECA complex before 8am on Saturday.
Be aware NO DRIVERS BREIFING OR COMPERTITION will take place until all Officials positions have beed filled.
So if this sounds like you or 1 or more of your friends or family post up in here and i add you to my list.
Cheers WayneO.
MORNING
SKIPPAN
Starter.. Wayne
Finisher..John
Spotter.. Timmy
Spotter.. Bobby
MINI WANG
Starter..
Finisher..
Spotter..
Spotter..
Spotter..
LONG WANG
Starter..
Finisher..
Spotter..
Spotter..
Spotter..
AFTERNOON
SKIDPAN
Starter.. Wayne
Finisher..John
Finisher.. Tim
Spotter..
Spotter..
https://www.sau.com.au/forums/topic/382413-deca-officials/
First DECA in 2 or 3 years I will be out of town otherwise you know I'd be there volunteering... :(
I echo what Jules said - best vantage point as a volunteer, AND you get free lunch - plus this month go into the draw for a $50 fuel voucher.... awesome!!
Since Bec is racing I'll take her spot as the long wang starter!
Long Wang starter is my spot :P (but I wont be there this month so you can do it ;) )
https://www.sau.com.au/forums/topic/382413-deca-officials/#findComment-6101787
me and 4-5 others are 100% dowm for spidpan fun. no volunteering though lol
volunteering dosent mean your stuck doing something all day, you can still go out in cars and that
you and the 4-5 others would be much appreciated for the help.
even do the wangs in the morning which means your free in the arvo to go on the skidpan
just a thought anyways :thumbsup:
https://www.sau.com.au/forums/topic/382413-deca-officials/#findComment-6106859
That's a shithouse attitude. DECA isn't run for the spectators, get your mates to volunteer.
we could make it a NON SPECTATOR event, so the only way people could get in is if they are driving or volunteering :whistling:
https://www.sau.com.au/forums/topic/382413-deca-officials/#findComment-6107888
That idea has been floated before. I don't necessarily think it's the best idea but the day is always short on volunteers as people come up to watch the spectacle (for free) and have no intent on ever helping. Maybe charging for spectator entry would be a good idea.
https://www.sau.com.au/forums/topic/382413-deca-officials/#findComment-6107902
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
