Guest dmallison
anyone interested in buying a Gtech, dont get ripped off and pay $399
can supply brand new in box including freight Australia wide for $160.
Call Darren on 0417898512 [email protected]
Well Ben - you can add my very ordinary effort of tonight.
R/T = .479
60' = 2.528
330' = 6.113
660' = 8.872
mph = 91.66
1000' = 11.178
ET = 13.118
MPH = 116.89
Km/h = 188.12
Must be able to do better then that - me thinks the driver needs more practice. :(
I'll scan the timeslip later - but you saw it.
hey b-man you wanna run :(
still at least your trying and the mph is good ;)
practice practice and practice
it would almost pay you to bring your car down to calder for a friday night you could get around 10-15 runs @ least if you try hard enough and the car can hack it now thats what I call practice
meggala
I know exactly how you feel Brendan ;) It's all part of the learning experience mate. I've had a drag meet where I started out with a 13.943 @ 117.35mph. In a way it actually makes you feel even better when you do finally nail a good one.
Gotta say though mate, you really suck at getting off the line :(
91.66mph at the 1/8th is very promising though. To give you an idea I had the following numbers on a 91.91mph at the 1/8th:
60' - 2.090
330' - 5.651
660' - 8.377
MPH - 91.91
1000' - 10.739
ET - 12.690
MPH - 119.12
My best numbers are:
60' - 2.143
330' - 5.492
660' - 8.188
MPH - 90.48
1000' - 10.531
ET - 12.473
MPH - 118.34
As you can see from my numbers above, it's a fine line between wheel spin and bogging it down. In the top run I had a good 60' (2.090) but then it light the rears up at about 70-80' and I lost out on ET. In the bottom one I came off the line slower and got better grip and therefore a quicker ET but lost out on top end MPH.
Yeah - I SUCK at getting off the line - It's much harder that you think hey.
If I give it too much, I seem to either wheelspin, back off and bog down - or the clutch slips (yeah still slipping on high boost)
That run was on low boost - high boost is slower (13.6) MPH is 117 -
I'm sure it is all driver related though.....
I was a bit disapointed to be honest - but hey practice make perfect :(
Hahaha... how hard can it be to go dead straight (well most of the time) for 400m? It's easy! Not when you've got a turbocharged engine that comes on boost like a mofo!
Keep at it mate. In another meet or two you'll have knocked 0.5sec off at the very least. You'll probably go mid/low 12's @ 120mph within the next two meets. And then when Brett gives you a shot on the Nittos you be into the 11's @ mid 120's. :(
He he - yeah me too - I had chronic axle tramp when trying to do a burnout - I think good suspension would help with the launches and traction -
But hey - it's easy to blame the car when most likely is the driver in my case :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
