5 SPEED MANUAL
Truly a weapon people, that's all I can say. I've had this car for about 1year and enjoyed every second I had with it.
This BEAST has 250rwkw Tuned by the boys down at UNIGROUP Engineering. Installed New Exedy cushion button Clutch recently.
Its done about 89,xxxkm.
Its had full GTR Replica Body work done to the front of the car which fits perfectly to the GTT by East Bear. Not many like this one going around in Sydney.
This car is in great condition, you will not find one that has been better taken care of. Always serviced on the dot and with top products - no cheap alternatives. This sale is extremely regretfull and would suit any extreme performance vehicle enthusiast. Please dont hesitate to call me with any questions in regards to the vehicle. Any reasonable offer will be considered
ENGINE
RB25 Standard Internals
T430 Internal wastegate Turbo
ID725CC Injectors
Front mount Intercooler
Walbro 255 Fuel Pump
Z32 Airflow Metre
NISTUNE Board remapped ECU
GFB BOV Plumbed back
3" Turbo back exhaust (special ultra Hi-flow metal cat)
BMC Cold Air Intake
NGK Iridium Spark Plugs
Splitfire Bluetop Coil packs
INTERIOR
Full Offwhite Leatherette Interior…
Red LED lights with switch
Pioneer head unit
Pioneer 6" speakers
Reflective Tint 15%
Custom guages installed BOOST, Vacumm, Water and Battery
HKS Turbo Timer
EXTERIOR
Full CUSTOME/Eatbear Bodykit
19" HIRO RIMS
DBA Slotted Rotors front
NISMO Side Blinkers
Dropped on King Springs
ASKING PRICE: $19,990 ONO
CONTACT: 0400 899 981
  • 1 month later...
  • 5 weeks later...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
