Just drive it nicely and you'll have no problems.
Have you just run the intake direct from the turbo to the inlet? If so brilliant throttle response!
yep direct from turbo to intake, its like accellerates before i put my foot down cause its that quick lol j/k but its almost instant power and spool just makes the engine run between 1/2 and 3/4 when boosting up hills and stuff, more boost higher the needle, hopefully my 800x300x76 fmic will help bring the internal temp down and icrease some hp
i was running my rb20det with no intercooler only around the block as would have big problems with changing gears, major power loss to the point of almost stalling/ cutout.. fitted the fmic 3 weeks ago and made the world of difference, reduced the over all running temp and a huge difference in power with NO cutout...
excellent great to get some feedback, should have my fmic by the end of this week, then boostin away till my hearts content, runs bloody good as is though, but feels like someones got there foot gently on the brake till 3 psi then there is a sudden power gain,,, and no its not just the boost gain, fells like an extra piston kickin in but its runnign smooth as??
Guest INASNT
That size FMIC is a massive overkill unless u r planning on running a 800hp turbo.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
