i currently have a D90- but its now being repalced under warranty! As a result im torn between 2 states of mind
- Keep the D90 my nly issue was its appauling build quality - better luck on the 2nd one
- Pay some extra cash and upgrade to the D7000
Anyone have much experience with the D7000??
https://www.sau.com.au/forums/topic/383133-d90-vs-d7000/
you must gotten unlucky dude. i've got a D90, it's been out in the rain, dropped, abused and mroe. would have about billion shots on it and it's marching as strong as day one.
having said that, I've played with a couple of D7000 and it's a clear upgrade. Work out if you want to spend the money though. It might be the D90 is everything and more than you want.
https://www.sau.com.au/forums/topic/383133-d90-vs-d7000/#findComment-6111429
Totally upgrade to a D7000. They actually feel really nice in your hand (I'm a canon person) and the upgraded AF and IQ is great. In the end, you sound like you're going to upgrade anyway! :)
Ended up going the D7000 :) My D90 was almost 2 years old and i really didn't want to get stuck with that technology for a few more years. Nothing wrong with the photos it took i was always blown away, but with higher IQ and Upgraded AF it just made sense. Its nice its also a little heavier and pretty much the same size with button locations so nothing to really get used to!!!!!
https://www.sau.com.au/forums/topic/383133-d90-vs-d7000/#findComment-6112866
  • 1 month later...
  • 4 weeks later...
AF-S 35mm f1.8 is a very nice affordable lens. Would be even better on a D7000 as it takes beautiful pics on my shitty d40x.
I did have a Sigma 50mm f1.4 which was unreal, just beautiful bokeh. BUT it had a mis-focus issue with the d40x, had it replaced with a 2nd lens and same issue.
A higher spec camera can calibrate for this i was told.
I think it was focused on her chin instead of her eyes.
45degree test showed the problem
F1.4
F2.8
https://www.sau.com.au/forums/topic/383133-d90-vs-d7000/#findComment-6225816
    • Alrighty, I'll have to grab a couple pics and type out something soon in another post. I haven't driven a modern X no, this would be the first one really. Yeah the rental boxes are always cheap as chips right? So I'd doubt that anyone was handing out GTs to go and abuse. But I s'pose I could be wrong for sure. New cars these days though? Pretty unimpressed with what I see now; 20 years and all that, like you said. It just kind of worked out to have these two cars now. I'm pretty pleased with that, don't need much else. I'm sure you lads are right about the temps and for sure, you wouldn't have much time to drive 'em down there if you all were like me. I do hate sweating all over the seats though😆
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
