So, last night I get out of the house & out to dinner with some friends (1st time in a year for me!).
Pickup a mate and head to the city, and there is this squeal from the front - I thought it was the RHS front CV boot considering its split and needs grease / new boot.
Touch the brake and the squeal stops, but comes back as soon as brake is lifted.
Park the car telling myself come Monday must get that CV boot dust cover replaced. Have a nice meal out with friends, laughing while they get tipsy, drop one friend off a Thebarton and head home down South Rd towards Flagstaff Hill to drop another friend off.
So, about 300m before South Rd / Daws Rd the revs suddenly flair to 5000rpm (just cruising, as I have been for 300kms since rebuild), boost guage shows there was pressure through the tubo system (albeit negative, but pressure nonetheless), complete lack of power, then it "catches" and drives normally the last 100m or so until the red light at South/Daws Rd. Stop, notice smoke coming out the back from underneath the car (oil on exhaust), green light, the gears flair again to 5000rpm and the car crawls forward.
Pulled over just past the intersection before the Fire Station, cut the engine, and find puddle of oil underneath the front of the engine, with a trail down the road from where I came from. I pop the bonnet and oil is all round the front of the engine, coming out from LHS (turbo side) front of engine. Dipsstick shows that there is bugger all oil left. 2 doors down is the caltex so I buy some overpriced oil, fill it up, start the engine and confirm the leak is front of engine, turbo side. Squeal just happens to be gone. Put it into Gear to park it around the corner and it goes nowhere, refuses to move an inch in 1st, 2nd, Drive or Reverse. Shut down; feel horrible in my guts.
Bus it back to mates place in Flagstaff, come back with ropes in his VR, and tow the stagea at 1am to my place in Morphett Vale.
Im not sure what to be looking for. The 3 belts at the front of the engine are intact and tight. Oil has been flung around the front end and its pretty messy in there.
What would cause oil to leak (bad/quick leak) and cause a loss of all drive to the wheels?
Engine is 300kms old, there was no knock whatsoever, and has been babied since the recent bottom end rebuild.
So whats gone wrong? I can replace brakes, suspension, turbos, radiators, intercoolers, etc, but never done pulleys, pumps, belts etc. Monday am I'll be ringing the workshop to pick the Stagea up for a tow and fix it - but what are your educated thoughts as to whats let go?
Oil leak, no drive.... what causes that?
Thanks in advance; I feel dreadful knowing that Ive just paid good money for a rebuild, engine was running beautifully, its now shit itself & currently I have not a cent to my name, and frankly dont know whats failed. :sick:
https://www.sau.com.au/forums/topic/383433-advice-on-what-went-wrong/
will you be taking it back to Shaun i know he is a champ with things that have gone wrong
my first thought was oil drain on the turbo split but i don't see that loosing all your power
man hoping it is something simple and under warranty to fix, sorry to hear Brendan
Im gutted mate. Absolutely gutted.
Id just like to know what causes zero drive & dumping of oil. I was thinking busted oil pump (had metal on metal squeal sound before it happened), but frankly I have no idea.
Yes it will be going back to Shaun; Ive been a loyal customer for 6yrs now.
That half crossed my mind when i read it pete. Thought straight up that the oil all over the engine could be from transmission (i take it that they run a transmission cooler in the radiator or somewhere front-wards), but if the engine oil level is low - zero, it just doesnt make any sense :-/
I've had a go now at cleaning up the mess in the front of the engine bay, started the engine for 5secs while I sussed the exact spot of the leak - looks like transmission fluid squirted out from a hose. Red colour.
Was so dark last night where I checked the oil level that I 'thought' it was empty - now its WELL above the full mark.
About to jack it up, empty out some oil into a spare container Ive got that I use for lawnmower 25:1 mix, and see what i can do about fixing the leak.
Where does the trans fluid get filled up from, and what type of trans fluid is required for R33-based Nissan autos?
yep drained the sump so now the oil level is within specifications.
cut the hose that was leaking (right at the nipple), and re-set.
found the Auto Trans dipstick, so just going to add the Dexron III fluid there :/
will doble check fluid levels then test (need to warm up the trans to get the correct fluid level).
thanks to all for your thoughts and suggestions
Thanks - it was a bloody awful feeling when it happened; sinking in the guts type. Didnt sleep over night, juts worrying over it.
At the time I was just explaining to my mate that I cant afford for anything to go wrong, hence advertised for sale, and then that happened (split AT hose); obviously I feared the worst.
Ive put in 3.5L of dextron-III ATF, now to let it sit for a while so I can get an accurate guage on fluid level, as I filled from the dipstick.
Good news is there is now power once again through all the gears; will test drive later on.
Keep tabs on the colour of the fluid on the dipstick too brendan, if it goes from being a red to a darky brown, it'll mean a trans fluid flush (when it goes that browny sort of colour its burnt and useless as tits on a bull). Dexron III is fine for the task
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
