  • 4 weeks later...
Here are my last steps to got my car ready =)
This was at the end of June
Later I picked up the car to Aalen (about 100km) by a trailer. Jonne from Sky-Engineering visited us to map mine and some other cars at High Import Performance in Aalen.
At first Jonne mapped the car on the road and after that on the AWD-Dyno
Here is the result and a little video (@1.35bar) the car couldn`t hold the boost...
The biggest problem now, the synchro of my 3rd gear is damaged =( And this after my big rebuild of 2 years...
Anyway... I was happy to get my car home =)
Arrived home, I got some new nice stuff for the GTR from Bene (Japo-Motorsport)
Stoptech brake kit with 355mm discs front and rear and 18" Nismo GT4 wheels with Toyo R888 tires for track use =)
Here my two setups:
Nismo LM GT4 in 18x9.5+15 with 265/35 R18 Toyo R888 Tires for track use
and
Varrstoen S2.2 in 19x10.5+12 with 275/30 Kumho Tires for street use
Here a little repair
At last, here my first shooting session at home =)
Now, a really big thx to Uwe, Daniel and Benny from High Import Performance (H.I.P.) for this really nice work!! Thanks to Jonne and Wayne from Sky-Engineering for the mapping. I also have to thank you to Marco, Marc, Dino and Bene (Japo-Motorsport) for your help!!
So, next things to do:
- repair the getrag (service at all synchros)
- put on the aero catch to the carbon bonnet
  • 4 weeks later...
Here you can see my last video from Reisbrennen 2012, onboard where you can see how I slide on my own lost cooling water
and here a nice video with a friend and his Evo6 TME together
Here the best pics of PixelRev ( http://www.pixelrev.de/ )
No other news until yet.
Okay, one thing. I want to change the Tein suspension. My Tein Typ RA is really to hard!!! Impossible to drive in city or Autobahn...
Maybe the suspension is good for track, but I want to have a lil bit daily use too.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
