Hey guys need to get new pads for the 31 so I thought an upgrade will probably work out not much more
Looking for something that uses a sliding caliper as 4pot brakes don't fit under my current wheels (and I'm not changing them)
So show me your old scraps, I will need rotors callipers and pads, and maybe lines too
I'm on the gold coast but can get to bris if needed (prefer gc tho)
https://www.sau.com.au/forums/topic/383911-sell-me-your-old-brakes/
What a shame; I recently threw out set of modified 296mm x 32mm Soarer rotors, calipers and dogbone adaptors that I made for my old R31!
It was a great upgrade that fitted under all types of rims (over 16"); you just have to swap the struts from right to left; so the caliper is on the leading side; not trailing side of the strut.
The parts would only cost $50 -$100 from a Toyota wrecker; you should do it.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
