Gday guiys. well, cll me dumb stupid or blind... but, i am having trouble trying to locate the oil pressure sender. I have done a search on the forums.. and looked where it suggested, but.. me still cannot see this sender unit? Can somebody help a helpless person here? Also, on an auto meter gauge.. what is an average psi rating that the oil should be at? Mine sits on 4 on the stock gauge, so what should mine be reading on the auto meter gauge once i get it installed?
Thanks guys.
hehe ...well on the top of my head the oil pressure sensor will be located on the side of the block either inlet or exhaust side will look like a round screw in solinoid with a wire coming of it , thats if its elec and not oil fed line ....... but should be down near the oil pan just above were it joins too the block just take your time it shouldnt be too hard too find ....
as too the oil pressure gauge well its hard too say each car may be different ..... should be around 60 psi when warm may be a lil higher when cold ....... well if your looking at a jap oil pressure guage , its around 4-6 bar... round a bouts ....
Yepp, inlet side, just a few inches behind the oil filter (further towards the firewall).
It's an electrical sender unit that has a weird tappered thread on it.
I bought an adaptor to tee in a pickup for my new gauge but it won't fit due the the tappered thread in the block.
Looks like I'll have to get one made up by a machine ing shop :thumbsup: Next oil change I'll take the sender out again and take it in and get one made up.
J
well, i think i have found it. its not in the best of locations... just like my mazda.. so.. how has people gotten in there and removed the silly thing? Counter tapered in to the block i hear? thats gonna make life very interesting!
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
