Hey guys, looking for a couple of cars to take about 6 people to the Canberra college formal on the 7th of december at the museum. the formal arrivals start at 6:45.
MIVEC is running my cousin in his evo and we need to take some of her friends who happen to appreciate the wonderful world of skylines. let me know ASAP if you are keen :) We can work out some form of payment.
cheers
melly :)
https://www.sau.com.au/forums/topic/384189-canberra-college-yr-12-formal/
Don't wanna be a deterrent here, but from what I've gathered - formals held at the museum are the MOST LIKELY to have RTA tossers in the carpark just after dropoff to potentially defect ppl...
That being said, when they pulled me up the only complaint I got was no front number plate, which I told them the front bumper hadn't been drilled to hold it yet and they just warned me on it...ehh
I could possibly be interested in the stagea if they like that as well. not worried about rta as the car is pretty much stock.
Good friends with mivec so could be a fun drive lol!
Let me know as im not sure what hours i will be working that week!
Edited by Verms
I'd be keen to come for a drive. Give me an excuse to make my car look all purdy. I've got a black 33 GTST. Can post a photo if you like when I'm on the computer. Used to do them all the time in my mustang. Yet to take the skyline for a formal so I'm keen.
Pretty stock but looks alright.
Tell me if they are interested.
Hey thanks! Can you PM me your number please
I haven't had any issues in the cars i've driven to formals and I have done one in mine and one in another Skyline, both were fine.
Hey Thanks, they are after Skyines tho.
Can you pm me your number too please?? :)
And Eiji... That's awesome...
I'm specifically talking about formals held at the National Museum
I got defected the day after i did national museum the year before last, at the end of my street.
probably a coincidence but still shit >_<
however on that note im willing to drive if you need more cars - black R33 GTR, black rims, exhaust and more
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
