  • Replies 5.5k
Posted Images
Having enjoyed two days of testing in Valencia, former World Champion Kimi Raikkonen is feeling "very positive' about his return to Formula One.
The Finn spent Monday and Tuesday driving a 2010 Renault R30 at the Circuito Ricardo Tormo in a private testing session. The Lotus driver got 171 laps under his belt as he reacquaints himself
with an F1 car after two years on the sidelines.
"It went well today and overall the two days have been helped me a lot," said the 32-year-old.
"Having not driven a Formula One car for two years and obviously with a new team, there is a lot to get used to. I'm happy because I was pretty quick to get back in the groove."
"Even though I was using a two year-old car and the Pirelli demonstration tyres, I learnt about working with the team and the engineers which means I can focus on the new car once we get to Jerez for the first official test.
"It was great to be driving an F1 car again and from that respect I feel very positive."
Having admitted after Monday's running that he was highly impressed by Raikkonen, Lotus' trackside operations engineer Alan Permane was pleased with how the 2007 World Champ upped his game on day two.
"We enjoyed another good day with Kimi in Valencia," he said.
"The morning was spent doing set-up work in particular with front and rear cambers. In the afternoon we ran very low fuel qualifying simulations with two new sets of tyres followed by a 27 lap run starting with a full tank of fuel.
"Kimi's pace improved from yesterday as we would expect and we completed several start, pitstop and clutch simulations. We were even able to finish early as we completed our programme ahead of time.
Overall it has been a productive and valuable two days."
http://www.planetf1....-Test-A-Success
Edited by tweety bird
"Sadly, it doesn't make the FF look any better"
oh the lulz
what a pig ugly panamera look-a-like
oh the lulz
Oh you'd better believe I laughed at that comment too!
They have a quickly growing McLaren section too.
Nothing beats the photo threads though, easily the best available
... oh sweet jesus what have caterham done
we can only pray to allah that this doesnt work as a concept, the last thing these cars need is to look even uglier
that hump up the nose will produce a small amount of pressure at the point of the front suspension, but can't see it making that much of a difference!
hmm maybe time to make one up and run some simulations :whistling:
ruben's going to race in circles.
According to The Associated Press, anonymous sources have revealed that the 39-year-old will be behind the wheel of the new Dallara DW12 chassis at the Sebring International Raceway for two days next week.
http://www.planetf1.com/driver/18227/7456663/Rubens-to-break-promise-with-Indy-test
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
