p3 times.
Pos Driver Team Time Laps
1. Lewis Hamilton McLaren-Mercedes 1m35.940s 13
2. Jenson Button McLaren-Mercedes 1m36.093s + 0.123 12
3. Nico Rosberg Mercedes 1m36.389s + 0.449 16
4. Michael Schumacher Mercedes 1m36.512s + 0.572 17
5. Mark Webber Red Bull-Renault 1m36.635s + 0.695 16
6. Pastor Maldonado Williams-Renault 1m36.765s + 0.825 17
7. Sergio Perez Sauber-Ferrari 1m36.781s + 0.841 19
8. Kamui Kobayashi Sauber-Ferrari 1m36.880s + 0.940 17
9. Sebastian Vettel Red Bull-Renault 1m37.039s + 1.099 15
10. Kimi Raikkonen Lotus-Renault 1m37.061s + 1.121 17
11. Nico Hulkenberg Force India-Mercedes 1m37.237s + 1.297 16
12. Romain Grosjean Lotus-Renault 1m37.274s + 1.334 19
13. Paul di Resta Force India-Mercedes 1m37.288s + 1.348 16
14. Bruno Senna Williams-Renault 1m37.425s + 1.485 14
15. Fernando Alonso Ferrari 1m37.465s + 1.525 12
16. Jean-Eric Vergne Toro Rosso-Ferrari 1m37.493s + 1.553 13
17. Daniel Ricciardo Toro Rosso-Ferrari 1m37.628s + 1.688 14
18. Felipe Massa Ferrari 1m37.831s + 1.891 14
19. Vitaly Petrov Caterham-Renault 1m38.701s + 2.761 19
20. Heikki Kovalainen Caterham-Renault 1m39.198s + 3.258 19
21. Timo Glock Marussia-Cosworth 1m39.796s + 3.856 18
22. Charles Pic Marussia-Cosworth 1m40.048s + 4.108 17
23. Narain Karthikeyan HRT-Cosworth 1m41.263s + 5.323 14
24. Pedro de la Rosa HRT-Cosworth 1m41.499s + 5.559 18
vettel and kovalainen where the only two on medium tyres. :thumbsup:
http://www.autosport...rt.php/id/98799
better mc boy?
  • Replies 5.5k
Posted Images
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
