  • Replies 5.5k
Posted Images
The race had a bit of everything except an alternator failure during the final safety car period.
^ like
I'm sure Tweety's covered it in one of his many tl;dr posts, but who's driving for Sauber next season? and does Senna lose his Williams drive?
Alonso deserved that championship. Vettel is very deserving as well...but Alonso only really lost points when taken out in Spa and Japan...it seems every weekend he got every bit of speed the car had and had so many sneaky results where he muscled the car around with no pace.
Definitely. Alonso did just about everything right this year.
Vettel was extremely luck in this race, with the lap 1 crash somehow not ending his day, and the pass under yellows being officially pardoned by the stewards...
I don't think Vettel was anywhere near as deserving - look at his results in the start of the season when the car wasn't quite the dominant force it usually is. He only came back into contention when Newey & co. got the thing absolutely flying, with 4 consectutive, uncontested, flag to flag victories.
Edited by hrd-hr30
kimi
"I went off at the last corner on lap 52 as I couldn't see well with my visor being dirty and fogged up," said Raikkonen, who finished in 10th position to become the only driver to have finished all races in 2012.
"Where I went off you can get back on the track by going through the support race pitlane, but you have to go through a gate.
"I know this as I did the same thing in 2001 and the gate was open that year. Somebody closed it this time.
"Next year I'll make sure it's open again..."
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
