Hi All,
Recently had a problem with my front torque gauge where the needle is not moving and showing torque distribution to the fwd. So i assume it's running on rwd. The funny thing is that there's no 4WD error lights on and i check the rear attesa ecu, there's no red led light blinking, i have check the g sensor and the indicator is ok, not in red color, check the attesa rear reservoir when the ignition on, fluids on the right level. when i switch on the ignitiion on i can hear the attesa pump is working.
i recently changed the gear box oil and front diff oil. gear box oil i used redline heavy shockproof. front diff i sue the same oil as well. but after reading through this forum or gtro found that shockproof oil doesnt do well in diff, so i changed to castrol manual transmission oil, and problem still there.
so i am really confuse as where the problem lies or is the front torque gauge not working? othes gauges in the console working fine though.
Please help.
Thanks
https://www.sau.com.au/forums/topic/384285-bnr32-front-torque-gauge/
you can try a bleed procedure just to see if the gauge works when the pump works. Take the drivers footwell trim out, there's a white plug that you unclip to activate the attessa bleed. Turn the ignition on (not engine), wait for fuel pump to finish priming (this might also be what you hear as I don't think the attessa pump primes on ignition) then unplug- you'll hear the attessa pump prime and the gauge should move too (up to half way). If your attessa system is not working and hasn't for a while the awd warning light can burn out- it should light up with the key turned to ignition.
Mate just because the g sensor indicator is showing ok doesn't mean that its working properly. The indicator is only a shock loading indicator and the sensor can still be faulty as this happened to me. Good luck with it anyway mate
the best bet now i think is do a bleed on the systems and see how it goes. Need to refer back to the manual for the full procedures. anybody knows which page? i did turn the ign on and unplug the two terminal on the g sensor and 4wd light pop out right after. plug it in the light still there and need to turn ign off and on then it's gone.
Have you had ur wheels balanced lately, or a wheel alignment?
Mine did the same thing after a dodgy alignment, the 4wd was definalty working cause I launched the thing hard on the highway lol
Anyway I didn't worry about it too much untill a couple of months later when I bought some new tyres and had a new alignment and balance etc then all of a sudden it started working again
Edited by GTR_JOEY
nope, i triple check all four rims are 17x9jj off+15. even tyre size are the same 255/40R17. just that the rear tyres are newer than the front and i measured the tyres width with a ruler, the rear is wider around 0.5cm.
Might be same size, but if they are different manufacturer or different model by same manufacturer, then they could be slightly different. The width is generally "nominal". It's the rolling diameter / circumference that is important.
It was odd that you got the problem you had. Ordinarily, the symptoms would be a jerkiness in the AWD system, because ATTESSA sees the slightly smaller (older) rears "slipping"" relative to the (newer) fronts.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
