  • Replies 96
Cheers, apparently the aircon unit is the same?
Could you pm me some bank details and I can transfer some cash
Also, do you have a handbrake lever? Must be in excellent condition, no cracks or splits :)
I will take a photo of the trim/bolt cover thing tonight - if you could also pm me your mobile I could mms to you if thats okay?
Thanks heaps
Thanks heaps
yeah i think they are the same,il let you no bout handbrake condition ive got one,let you no 2moro,sms me on 0431 540 141
Still got the boot interior? Also do u have the eye level brake light from the parcel shelf and a rear seat belt clip, base?
yeah got boot interior stil,il have a look it it has eye level brake light,got seat belt clip base
yeah it is a lip,il get closer pics if ya want,make an offer,yeah il post
more pics would be great. if its an actual lip ill take it...looks like a little wing to me.
also power steering pump?
Edited by -Lucas-
Let me know what u want for them, I'll be up that way sonish
3inch cat back exhaust $250
front hubs,knuckles,control arms,castor arms with new bushes,upper control arm with new bushes, $150
rear cradle with hicus lock bar,$100
shimmed r32 lsd diff $200
5 bolt shafts $100
seats front and rear $100
hks coilovers $600
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
