  • Replies 96
Cheers, apparently the aircon unit is the same?
Could you pm me some bank details and I can transfer some cash
Also, do you have a handbrake lever? Must be in excellent condition, no cracks or splits :)
I will take a photo of the trim/bolt cover thing tonight - if you could also pm me your mobile I could mms to you if thats okay?
Thanks heaps
Thanks heaps
yeah i think they are the same,il let you no bout handbrake condition ive got one,let you no 2moro,sms me on 0431 540 141
Still got the boot interior? Also do u have the eye level brake light from the parcel shelf and a rear seat belt clip, base?
yeah got boot interior stil,il have a look it it has eye level brake light,got seat belt clip base
yeah it is a lip,il get closer pics if ya want,make an offer,yeah il post
more pics would be great. if its an actual lip ill take it...looks like a little wing to me.
also power steering pump?
Edited by -Lucas-
Let me know what u want for them, I'll be up that way sonish
3inch cat back exhaust $250
front hubs,knuckles,control arms,castor arms with new bushes,upper control arm with new bushes, $150
rear cradle with hicus lock bar,$100
shimmed r32 lsd diff $200
5 bolt shafts $100
seats front and rear $100
hks coilovers $600
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
