fkn LOL - I love dyno hp debates. So much BS floating around. Even with dyno chart print outs, you never know what the tuner/workshop does in 'tinkering' with dyno settings load/ramp/blah blah to yield numbers.
*puts flame suit on*
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6150152
  • Replies 46
Posted Images
Sigh, a stock r34 gtr engine will not make anymore than 300awhp, 250-280hp more likely. There are too many restrictions in stock form.
With a decent exhaust and 1bar of boost they make around 330awhp, a stock exhaust hides abit more than 20hp, more so around 40-60hp since the stock exhaust doesnt let the turbos go past 10-12psi either.
If its got an n1 oil pump and new clutch, over 9000. :)
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6151071
See :)
It's apparently got more than one oil pump though. So should be safe to assume over 18000?
class clown right here, and you have never made a mistake? or just ur parents 9 months before you were born?
delete thread, thanks to the guys that actully helped and for the others, next time ill just go to a disabled school because ill get more out of the kids there (:
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6151178
Hey that was cute, gold star for effort.
Next time, did you know that there is this new thing called Google? It's pretty good, has some info, lots of colourful pictures n shit, you'll love it.
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6151401
well why have a site were you can post things and get imfo
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6151878
I do agree.
And so have countless people since the creation of this site. Which would be why this question has been asked before and there is plentiful information on it.
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6152015
I do agree.
i started this post because i needed to know within 10 mins of asking the question!
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6152472
I'm sure they did, what a good Samaritan.
Just as a matter of interest, would said good Samaritan that PM'd spence mind posting in here? Just because I, and I'm sure others, would like to know for sure from another R34 GTR owner how much they make in stock form? Surely would have been easier for this mystery person to post their response in here where the question was asked and other future readers may look for an answer? Or is the answer a secret that only 34 GTR owners are allowed to know?
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6153568
i would love to.. but how do i get deleted post's back up
so much of a smart ass
https://www.sau.com.au/forums/topic/385189-r34-gtr/page/2/#findComment-6154003
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
