  • Replies 110
Do we need anything besides our cars/ourselfves and some skill? :)
Also where is the place located (suburb) ?
Im interested  :headspin:
Roadworthy car, valid license(?), skill is optional.
Mt cotton is the location, off Mt cotton road, not sure if mt cotton is its own suburb or not. Its only 10 mins off the hwy going off at the exit just after the Logan hyperdome if that helps.
It is confirmed.
Sunday 23rd May 2004. Starts about 7:30am @ Mt Cotton Driver training centre.
$170
Half day skidpan (4hrs), half day LVMA (cone tracks, time trials), and lunch for paying drivers.
16 places,
Hey Slip save me a spot mate I will have to pay you in cash though if thats cool :headspin: last time I tryed putting money into you account U didn't get the money & I don't know what happened to $50 bucks of the money I tryed to transfure :) it went walk about :Bang:
yes. the skidpan is 4hrs, the lvma is 4hrs, and we get a lunch in between. lunch was quite good last time. Only paying drivers get lunch of course.
LVMA is more time attack, but there will be some big slides pulled as things get a bit silly.
slip when does money have to be in by?? i'd like my name in too :S
ASAP Nick! Its always first in first served for these. You don't want to miss out. Its the best fun you can have, and its all in a safe environment.
Only 6 spots to go.
