Hello everyone, this may sound like a stupid question to some, but this is a legit question, i'm pretty sure i know which way i'll go but i thought id ask the question.
Engine; RB25 NEO
Head has to come off for the sole fact of fitting restrictors. It hasn't overheated or blown a head gasket that i'm aware of. But to fit the restrictors the head has to come off.
I'll be replacing the head bolts with either factory Nissan ones or some ARP ones if i decide to fit a metal head gasket.
My question is, for a simple gasket change, should the head be faced to ensure a good seal again? Thinking about it myself, using a factory Nissan gasket i dont really see an issue with not facing it. Obviously facing it would give a nice flat surface for sealing.
I'm aware that i fit a metal head gasket i'll have to face the head.
Thanks, Daniel.
Just grab a straight edge, and see if both the head and block a straight, if within spec whack it back on (when using a standard gasket)
and make sure you clean every last trace of old gasket from the block and head
Yes i'd be doing both of these.
Is it worth going with a metal head gasket? This engine will be flogged to shit. It may some day be asked to make over 300kW, but not any time soon.
imo, no
Standard gasket will be fine.
If you are worried about having to pull the head off at a later date for what ever reason, than don't.
Because if something goes bang and the head needs to come off than a head gasket will be the least of your worries
imo, no
Yeah ok, cool. I've never had an issue with a factory Nissan gasket.
Does anyone know how many restrictors the NEO has? I'm hearing mixed reports that its two or three. I'm quite green when it comes to NEO's.
Two.
simple solution yes, but a worth while mod?
Doesn't hurt to grind it, but if there is no scratches that will prevent the gasket sealing you should be fine
I also recommend to lightly run a 2nd cut file over the block deck after you've scraped all the gasket off
I've used a fine grinding stone before, works a treat. Just takes that layer of crap off.
Nope, there is a third unrestricted oil gallery for the VCT towards the front of the block, this should not be restricted at all.
I bought 2 x 1.5mm Tomei restrictors for my Neo which I will put in over the top of the 2 x stock 2mm restrictors. Some people recommend completely blocking the rear restrictor altogether and just using 1 smaller restrictor in the other one, but it depends on your oil pump choice.
By the way I found out that the Neo's come with an N1 oil pump as standard.
So one for the head itself as it has solid lifters. And one for VCT correct?
I shall only need to restrict the main one to the head?
Yeah I thought it was 3, one for VCT. Obviously you wouldnt block the VCT.
How come the NEO has both restrictors but an RB26 has its rear blocked. The NEO has solid lifters aswell.
It will be used or circuit primarily, so at constant high revs for 20 minute periods.
It will see the occasional drift day and driven on the street from time to time.
I plan on just using the N1 pump.
Get to know your engine now, it won't be around for long with that pump on the front of it.
I haven't had an N1 pump survive any type of road use let alone track use in the last 4 we sold and half a dozen failures we saw on customers cars that came in the door with 0 oil pressure due to smashed gears. One of them was a car that was trailer to the dyno and didn't even make it through the tune
Yes im well aware of N1 pumps being shit.
However that seems to be with the ones manufactured in the last few years.
The ones fitted to engines from factory seem to be ok.
I do have a Tomei pump I could use, but the thr crank has to come out to get a collar fitted.
Yes if you have one from an actual N1 then you should be fine
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
