hey guys, just wondering on your oppinions on what size i should go for with my exhaust. I own a r31 n/a skyline (rb30) and have been reading that a 2 1/2" system does it wonders, which it might on the track with your foot planted on the noise pedal! but its only a 3 litre and its my daily and i dont want to kill my toque, but maybe 2 1/2 isnt much at all and i wouldnt be endangering my performance and it could do it good! I plan on having extractors with a 2/12in outlet and then a hi flow cat straight out to the cannon.
soo what are your thoughts? 2 1/2in good or bad? be very happy on your thoughts :)
https://www.sau.com.au/forums/topic/385278-exhaust-size-for-rb30/
Hey mate, I had the exact set-up on my ol VL, it worked very well and gave noticible power gains. The only thing I would recommend is a muffler, I really liked the sound for a couple of weeks after installing it but after a while I got tired of the drone and installed a 'hi-flow' muffler between the cat cannon/endpipe.
I dont know how people put up with it?!~?!?!
the muffler under the bum of the Supra is HUGE! plus a centre muffler as well, and it is loud while breathing through the 2 tiny standard turbos and standard dump and mid pipe
  • 3 weeks later...
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
