Hey guys im going for a retune on Monday but this time im getting 555cc nismo injectors and a z32 afm put in.
My previous tune made 246rwkw on 16psi but bleeds back to 15 with supporting mods:
RB25DET with standard internals
JPC Highflowed turbo
Walbro 255lph in tank fuel pump
3" exhaust with high flow cat
FMIC
Splitfire coilpacks
Power FC
My question is how much boost can a highflowed turbo handle? The previous owner had highflowed the turbo at JPC and apparently JPC told him that it can handle 400-450hp?? :blink:
Im hoping that 18psi can see me around the 260+rwkw?
Cheers
Levi
Edited by Levy
https://www.sau.com.au/forums/topic/385722-jpc-highflowed-turbo/
i know that if put more boost in it will shorten the life span of the turbo but i want to know what would be a safe psi as a daily. Im well aware of the risks involved but i just want to hear some oppinons, not smartass comments. if your gonna take the piss take it somewhere else or keep it to yourself :cheers:
Edited by Levy
yes i do, boost doesnt normally kill turbo's its more the shaft speed etc, its a highflowed steel wheeled turbo, so i would expect it to sit on 22psi comfortably,
depending on what you use your car for ie daily or circuit etc, tune your car to suit, daily i would run 19psi on high boost, but on the track maybe 14 to keep the engine happy
Mate there are so many variables. Comp wheel/turbine blades/size/material, quality of porting, bearings used, etc etc etc. Not all highflows are the same, so unless you tell us the exact specs of the turbo, it will be impossible to say exactly what it can do.
The best thing you can do, aside from contacting JPC about it, is to give it to your tuner and ask him to tune it to the turbos efficiency. They will be able to figure out.
Makes sense to me, just the answer i was looking for thanks man i appreciate it :thumbsup:
Dont know the specs, so i guess il leave it to the tuner
Cheers
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
