  • Replies 82
lol woops knock the 1 of the front of that
lol
you mean the zero off the end..
origial ones were $22 to start with.
now gen 2 is $40 delivered
but if your one comes connected to an RB26 then fair enough. :D
fark it
i'll just throw it at the next door neibours dog instead
lol
Pm sent re engine, haven't seen any cash yet
first in with full amount wins it
Injectors sold pending payment
plenty still left including roll cage, Blitz fibreglass bonnet, Wilwood brakes, intake kit, whole registerable shell, fuel pump and surge tank, gauges and more!!
Update of items still for sale, some prices reduced PLUS new pics added:
Rb26dett rebuilt long motor – Deposit taken
Wilwood 4 piston Superlight front brakes with Brembo 324mm drilled discs $1,300 Now $1,200
Includes three brand new sets of spare pads, bracket adapter kit and braided lines. Rotors and pads have plenty of meat left on them.
R32 Gtr N1 turbos $1,000
R32 Gtr Garrett -5 turbos, done approx 15,000km $1,500
Wiring loom for R32 Gtst Rb26dett conversion $200
Intercooler 600x400x100mm and piping to suit Gtst $300
Stock Rb26 BOVs and piping (BOV return pipe already sold) $200
Intake kit including copy Greddy pipe to intercooler, twin pod filters $400 $350
5Zigen 3”stainless steel turbo back exhaust $250
OBX manifolds $250
Stock Rb26 front pipes $150
Stock Rb26 exhaust manifolds and dump pipes $40 each
Intank Gtst fuel pump $100
Fuel pressure regulator $100
Fuel cooler $40
Oil catch can 1L $50
Turbotech manual boost controller $10
Bolt in 4 point roll cage $500
Blitz R32 Gtr fibreglass bonnet $650 $600
Top condition with N1 lip and aero catches
R32 Gtr rear wing $150
Has a couple of chips but otherwise good condition
17 x 8 rims, no rubber $500 (see pics below)
4 Door 1993 R32 Gtst shell
Non rolling, previously registered in Vic, suit track use $1000 or $1500 with bolt in roll cage. Shell is mostly stripped out except for dash and steering column. Does not include wheels, suspension, brakes, bonnet, wing, headlights. PM me for more details.
Stagea rear calipers and rotors $150 $100
Greddy strut brace front $150 $130
Custom strut brace rear $120 $100
Nismo control link set, suits Gtst $500
R32 passenger seat, good condition $100 $60
SAAS Steering wheel (no boss kit) $100
SAAS gear knob $50
Tomei 300km dash $350
M's turbo timer $50
Apexi 2” Power Meter gauge $80
Apexi Multichecker (Engine check system) $300
New in box with certificate of authenticity, manual etc
Speco meter tacho 2.5” $60
Sold stuff:
Rb26 standard turbos rebuilt with steel wheels
R32 Gtr Power FC with hand controller
HKS split dump pipes
OBX tuned length front pipe
Walbro 305LPH external fuel pump and 4L surge tank incl braided lines and Speedflow fittings
Yellow jacket coil packs
Oil filter relocation kit and 30-row cooler, with Speedflow fittings
ASI 52mm dual core alloy radiator, Blitz cap, JC-project silicone pipes
MDU Gtst suspension
Bride drivers seat with super low rail
R34 Gtt factory steering wheel
Autometer Sport-comp 2.5" boost gauge
EBCR 2” exhaust gas temperature gauge
AEM wideband sensor gauge kit
Short shifter kit, brand new in box
550cc Siemen Denso Injectors, new O-rings, seals
Fark!
Typo above... exhaust is $200 cat back as the front pipe is already sold
Mate have you still got the wiring loom? I am putting a 26 in my R32 at the moment. I assume this will fit a 2 door OK? Best price for it delivered to 4174 and I'll take it off your hands this week.
Kirk 0414 236 724
Hey man. I'm keen on the exhaust but not sure if I can transport it. Would it be possible to get it shipped to Goulburn, 2580? OR I'd be willing to pay someone to bring it down. I need to get rid of the dirty exhaust that came with my car.
Kirk 0414 236 724
the loom with the head is sold
i have another loom you can have for 150+ shipping this out of a r32 but you will have to modify it
can ship but i'll need to get a quote.... probably be around $100 maybe??
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
