Im not sure about everyone
but there is something on the road that is starting to really damn annoy me and it must stop
Ill set the scene , I was lying on my couch today half asleep enjoying one of my last days of holidays. The sun was out the birds were making peaceful noises, I had a ice cold bourbon at my side and was in heaven
I then got a very rude awakening by a high pitched dull monotonous tune!
YES IT WAS THE evil mr whippy , for the Fifth FUc*ing time this week!
driving slowly up and down my street in a 1950's ice cream truck painted pink!
Does anyone else have to contend with this sort of menace, what do you suggest I should do , take out a restraining order against mr whippy???
your advice would be appreciated
https://www.sau.com.au/forums/topic/38655-a-new-menace-on-the-road/
i love the sound of Mr Whippy coming down the street reminds me of being a kid again ...... when i was little i used to get so excited over that sound and started concoting ideas about how to get $2 for an icecream out of my folks.
Nah sorry VOTE ONE WHIPPY!!!
LOL - this brings back memories of the Simpsons episode where Homer's goal in life is to be 300lb so he can work from home... At the end of the episode, Homer steals a ice cream van and drives it to the power plant to save the reactor.
Anyway, after he drives through the fence, all the staff jump on the ice cream van and try to order ice creams.. LOL
Anyway, you have to be there,
J
P.S. Isn't it funny how there's a Simpson's episode for every 'moment' in life :)
I went to the danny green boxng fight at couple of weeks back and when singing the national anthem it had more of a dance tune background music...
I'm thinking lets make a mr whippy drum N Bass remix or break beats remix of it.. with a few vocals...
"Put your hands up in the air, put your hands up in the air......"
Don't worry about the music comin out of his speaker worry about the sad arse engine that sucker is running.
If I were you id run out there and give him the low down on how to strap a bug mutha RB26DETT to that sucker, chuck on some nitto 555r's and rock that baby down the motorplex!!!!!!!!
Ohh yeah grab one of those sundae thingo's in the cup he sells, they taste mad!!!
lol
how bout "Put your hands up in the air.............if you want ice cream, Put your hands up in the air..............if you want ice cream"
the mr whippy song is called Greensleeves...... Dan I would buy a break-beats mix of that hahahaha
Whenever i hear the ice cream I think of Eddie Murphy in Delerious - ICCEEECREEAAMMM THE ICECREAM MAN IS COOOOMMMMMING. I've got an icecream and you cant have none, cause your dads an alcoholic and your on the welfare.... you cant afford it, you cant afford it. :)
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
