  • Replies 139
Radiator still for sale? is it in good nik?
Pm me please
Yep rad is in good condition, couple of minor bent fins on the back but perfectly serviceable
pm reply coming your way soon
Front and rear seats sold
Plenty left (except interior bits) incuding rims, immaculate front guards and doors, airbags, whole dash, airbag steering wheel, Gtr strut brace (rear), castor rods, hubs, suspension, turbo timer, a/c controls, alloy radiator, clear side indicators and more......
UPDATE!
Shell has now gone to the scrap yard but I still have the following parts available:
Happy to arrange for shipping of most items at buyer's expense.
Hubs front only $150 or $300 front and rear.
Rear sway bar $50.
Rear cradle $100 no brakes or diff, one bent control arm, includes hubs.
Front stocker suspension with lowered springs and rear HKS suspension $130
Rear boots are torn but otherwise fine, no leaks.
Front guards $100 each
Immaculate condition, silver, include Gt badges
Clear side indicators $40 pair
Guard liners $50 pair or $30 each
Side skirts $100 pair
Fog lights $60 pair
Rear wing $100
Doors $130 each
Immaculate condition, trims not included
Side mirrors $30 each
19 inch rims $700
Maxxis rubber with heaps of tread.
Alloy 50mm single core radiator $140
Dash pad $150
Perfect condition.
Ignition barrel with key $50
Indicator and wiper stalks $15 each
Climate control unit $40
Passenger airbag $100 pick up only
Front and rear seatbelts $200
Nismo gearknob $40
Din pocket $20
Sony Xplod Stereo with remote control and manual $60
Blitz Voice Guide turbo timer $50
Interior B/C pillar trims $30 each or both for $50
ABS unit $80
ABS bracket $20
Rb25 AFM $50
Aftermarket castor rods $70
Power steering rack $50
Nissan tool kit $15
5Zigen tip $50 (Has the 5Zigen stamp on the tip, muffler is damaged)
Cat to muffler 3” exhaust pipe $40
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
