  • Replies 139
Radiator still for sale? is it in good nik?
Pm me please
Yep rad is in good condition, couple of minor bent fins on the back but perfectly serviceable
pm reply coming your way soon
Front and rear seats sold
Plenty left (except interior bits) incuding rims, immaculate front guards and doors, airbags, whole dash, airbag steering wheel, Gtr strut brace (rear), castor rods, hubs, suspension, turbo timer, a/c controls, alloy radiator, clear side indicators and more......
UPDATE!
Shell has now gone to the scrap yard but I still have the following parts available:
Happy to arrange for shipping of most items at buyer's expense.
Hubs front only $150 or $300 front and rear.
Rear sway bar $50.
Rear cradle $100 no brakes or diff, one bent control arm, includes hubs.
Front stocker suspension with lowered springs and rear HKS suspension $130
Rear boots are torn but otherwise fine, no leaks.
Front guards $100 each
Immaculate condition, silver, include Gt badges
Clear side indicators $40 pair
Guard liners $50 pair or $30 each
Side skirts $100 pair
Fog lights $60 pair
Rear wing $100
Doors $130 each
Immaculate condition, trims not included
Side mirrors $30 each
19 inch rims $700
Maxxis rubber with heaps of tread.
Alloy 50mm single core radiator $140
Dash pad $150
Perfect condition.
Ignition barrel with key $50
Indicator and wiper stalks $15 each
Climate control unit $40
Passenger airbag $100 pick up only
Front and rear seatbelts $200
Nismo gearknob $40
Din pocket $20
Sony Xplod Stereo with remote control and manual $60
Blitz Voice Guide turbo timer $50
Interior B/C pillar trims $30 each or both for $50
ABS unit $80
ABS bracket $20
Rb25 AFM $50
Aftermarket castor rods $70
Power steering rack $50
Nissan tool kit $15
5Zigen tip $50 (Has the 5Zigen stamp on the tip, muffler is damaged)
Cat to muffler 3” exhaust pipe $40
