hey mate i'm looking to convert my auto series 2 to manuel u said $200 for conversion.i'm willing to pay that..would you be able please list the items involved and what condition there are in?....cheers
conversion is no longer for sale
see post above for whats left
  • Replies 139
Righto, someone take this stupid passenger side door off my hands
50 bux pick up
bargain as it's in top condition with glass etc, just missing the interior trim
or happy to butcher it for parts if anyone needs them... handle, side mirror, motor etc
Side skirts and 5 zigen exhaust tip sold
Here's what's left:
-Rear cradle $100 for the whole thing including hubs and control arms (no brakes or diff, one bent control arm)
….or can separate parts off it, see prices below
-Rear sway bar $50
-Rear upper and lower control arms $100 the lot
-Hubs $250 for fronts and rears
-Rear wing $40 (excellent condition, no LED light, bargain)
-Passenger door $80
-Passenger side mirror $20
-Wiper stalk $15 (indicator stalk sold already)
-Sony Xplod Stereo $40-Comes with remote control and manual
-Passenger airbag $50 prefer pick up as I'm not sure how well it would go in post
-Ignition barrel with key $50
-Front & rear seatbelts $20 each or $50 for all four (no pic excellent condition)
-Climate control unit $30
-B/C pillar trims $30 each or both for $50 (awesome condition)
-ABS unit $50
-ABS bracket $20 (or free if you buy the ABS unit)
-Power steering rack $50
-Cat to muffler 3” exhaust pipe $40 pick up only
Also got a heap of parts from an R33gtr I wrecked so ask away
Do you have all the bushings, bolts and brackets for mounting the sway bar? Especially the metal brackets that mount it to the chassis(they go round a rubber bushing to hold it steady)
I don't care about the bar, too much trouble to ship, but I'll give you 30 for everything else but the bar if you got all the pieces. Shipped to Perth?
i might do but fck knows where they are at this point, would be probably not worth the hour to find all the bits ;)
Now sold:
-Side skirts
-5Zigen tip
-Wilwood 4 piston Superlight front brakes
-Front lower control arms
Taking offers on most of this stuff so ask away, it's all that's left of the wreck....
-Rear sway bar $50
-Passenger door $70
-ABS unit $50
Now sold:
-Rear hubs and arms
Still for sale:
-Rear cradle $80
-Rear sway bar $50
-Hubs $100 front hubs- includes abs sensors and uprights but no lower control arms
-Passenger door $70
-ABS unit $50
-'Gt' quarter panel badge $20 posted
Also got this other shit for sale:
-SAAS Steering wheel (no boss kit) $80
-Quick release boss kit $40
-SAAS gear knob $40 (as new condition)
-M's turbo timer $40
-Apexi 2” Power Meter gauge $60
-Speco Meter 2.5" tacho $50
-Racetech oil pressure gauge $50
Hey mate, I didn't sift through all 7 pages..
Just wondering if you have the sun sensor for the climate control, the one that sits on the passenger side of the dash. Apparently mine has died. :(
nah dash is sold so that would have gone with it
i still have a 33 gtr dash floating around, not sure if it's the same but i might have one on that
  • 1 month later...
Hey mate,
PM sent earlier in the week about the power steering rack + if you had anything else left over from this car at this stage. Cheers.
