doing a holaday clean out and putting everthing i find up for sale
iv striped a few 33s over the years so if its not listed i can look for it
parts are in storage in Colac but every weekend im driven back and forth to Ringwood
so if any body wants parts i can deliver on a sunday night or a friday arvo
or order the parts and pick up in ringwood 0400102360
striping a r33 s1 coupe any thing you guys need just ask im only keeping gear box and rearend
rb20 head looks to be in good condition with inlet $150ono
rb20 head bad condition snap belt $50
r33 passenger side light
r33 mirrors $20
rb20 bottom end looks to be in good condition $100
r34 na diff and axels make a offer on the stuff
rb25de neo ecu
stock 33 front pipe with cat $50
jdm r32 cat $50
r32 turbo air box $200
r33 racks x3 $50 each
r33 x member $50
so much more ill keep adding need any thing just ask
thanks Matt
Edited by dreadr31
Just wondering if you have any other pics of the underside of the inlet manifold, im having problems with splitting hoses under there and have been trying to get a full pic of where everything goes under there.
nah havent got cooler bits
stuff that have sold
dash
doors
side windows
carpet
parts up date
2 33 gtst seats quick sale $50 for the per
rb25det long motor not 100% sure on condition only idle it in car no noises no smoke
car had 66000ks on it, sat in a shed for 8 years after accident $800 firm
Edited by dreadr31
Is there a box on the dash that looks like that? did the car make a clunking noise for 10 seconds or so when you turn the ignition on?
if you have the box and does not make the noise how much posted to vic 3200.
Edited by W0rp3D
Cant tell from the pic but it looks like the box on top of the dash left of center with 2 wires running to the loom just under the windscreen.
Hi mate, will you ship the bracket that the bonnet latch and horns are attached to from the r33 gtst, to perth 6155? If so how much you want for it?
pm sent
AFM how much ship to darwin NT millner 0810 what BOV you got in there????
i got a spear afm got to wait till we finsh a car first to see if we need it
keen on the drivers side mirror do you have it still ?
yerp
Hi mate,
I will take the following pieces;
- the plastic dash piece which covers the whole day (basically the big plastic piece right under the front window and the side control panel arms with window switches.
How much?
Hi mate,
- Upper side door plastic trim (the area where people usually mount side gauges).
How much?
Hi mate,
i would be interested in the rear boot trim and board if you still have it?
Let me know and give me a perice, and how much for shipping to perth.
all gone sorry man
Pm sent
replyed
Hi mate,
How much?
window switches have gone
dash pice it ok small crack under the cluster
  • 4 weeks later...
i am now stripping down the motor if any one needs parts
turbo sold
also people can low ball me on the rb20 parts haha
Edited by dreadr31
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
